| New Reply |
A bunch of basic questions on electrons |
Share Thread | Thread Tools |
| Aug20-11, 04:58 PM | #1 |
Feel free to answer any subset. I'm not a science person, so apologies in advance for some of the absurdity.
1. When heat up some piece of matter (e.g., a rock), do the the electrons (of the atoms of which the rock is composed of) start moving faster? If so, then why do we observe temperature as a continuous phenomenon - or, at least, pseudo-continuous with millions of different possibilities (e.g., 25.743 C°, 245.24565435 C° etc.) - after all, the elements that are in the rock are bound by a very low energy levels (say, n=3). Therefore, the angular momentum can only be 0, 1, 2, which would mean that only three different temperatures are possible (assuming you would introduce the heat uniformly throughout the entire rock). What am I misunderstanding? Another reason I am wrong is because I've read that temperature does not have an upper limit, however, the angular momentum does have an upper limit... 2. I've seen pictures of electron clouds that appear to diffuse outwards in a continuous fashion (like a picture of the bivariate normal distribution) to positive infinity and negative infinity. I've also seen picture where it's just a geometric shape (a sphere or a oval sphere or a spherical cone) that's bounded in space. Which one is more accurate? Asking in another way: For a particular atom in Melbourne, is there a nonzero probability (albeit extremely small) of its electron appearing in the US (while the nucleaus stays in Melbourne and nobody does anything to it)? 3. Is there a mathematical pattern that produces the standing waves of the subshells we know of? Or is it just arbitrary and we don't understand it yet? 4. What does it take to kick out an electron? How often does it happen in our daily lives? What kind of wavelength and what kind of intensity is required to kick out an electron of an hydrogen atom, say? 5. Why are noble gases and other non-bonded atoms colorless? Why is that only after bonding the molecules assume color? 6. Why do we not have color photographs of molecules? Shoulnd't the wavelength be visible at that scale? 7. Why do the planets of our solar system have such large variation in color (blue, red etc.)? The visible spectrum is so extremely small - why does the emission/absorption just happen to take place in that range? Or are the emission/absorption characteristics so extremely idiosynchartic for different matters at all wavelength ranges? 8. When I look at the 2p (x,y,z) subshells I notice that when you put them together, then there will be some overlapping of the clouds (does that mean that the overlapping regions have additive probabilities of the two subshells)? 9. I once asked why the electrons and protons don't collide due to the magnetic attraction. Someone said that the laws at the atomic scale are different. However, I then read on wikipedia that electrons obey electromagnetic rules. What gives? Thanks! |
| Aug20-11, 06:00 PM | #2 |
1. Yes and no. The temperature is due to the motion of the atoms, not their electrons. The temperature only appears continous in systems with a large number of atoms because the gaps between the enery levels become very small.
2. The diffuse cloud is more accurate. The "bubbles" you mention are constructed such that there is a certain probability of finding the electron inside them. 3. We have a theory which predicts the states of quantum systems and is in agreement with experiment. If this is what you mean, then yes, we understand it. 4. This happens all the time. You could say it happens in any chemical redox-reaction. 5. The colour of gases arise from their absorption/emission spectra. You can read about this in any basic physics textbook or on wikipedia. 6. See above. You can only define the colour of an object from its emission spectrum. A molecule absorbs and emits light as a whole, so you cannot obtain a colour photograph of one the same way you can for macroscopic objects. 8. Not neccesarily. It depends on the coefficients in their sum. This question may be difficult to answer precisely without knowledge of linear algebra. |
| Aug20-11, 06:22 PM | #3 |
9. The electrons and protons in an atom most certainly do "collide." Or at least they overlap. The s-wave orbital for an electron is nonzero at the origin, and consequently there is a nonzero probability of finding the electron inside the nucleus. In most cases there is no interaction simply because there's not enough energy available to do so.
For example in the hydrogen atom, the electron and proton cannot unite to form a neutron because the neutron is heavier and outweighs the proton and electron combined. For other atoms, such as Al-26, the electron may indeed be captured, and one of the protons is turned into a neutron causing a neutrino to be emitted. |
| Aug20-11, 10:18 PM | #4 |
Mentor
A bunch of basic questions on electronshttp://hyperphysics.phy-astr.gsu.edu...um/hydsch.html |
| Aug21-11, 11:42 AM | #5 |
[tex]{E_n} = - \frac{{{m_e}{e^4}}}{{8{\pi ^2}\varepsilon _0^2{\hbar ^2}{n^2}}} = - \frac{{13.6{\rm{ eV}}}}{{{n^2}}}[/tex] You can see that it takes a photon of at least 13.6 eV to liberate a ground-state electron from a hydrogen atom (photoelectric effect). This corresponds to a photon of 91 nm, which is in the ultraviolet. Just beyond the visible spectrum you have IR and UV. Near-IR and near-UV can absorbed and emitted electronically by most materials just like visible light, but (if I remember correctly) the absorptivity/emissivity in this range is typically lower. Deep-IR can only be absorbed and emitted thermally, so in this range you see very little visual contrast between materials of similar temperature. Far-UV and X-rays tend to interact via scattering. I am not sure how much variation in "colour" one would see when viewing the world in this band, but probably not very much. Microwaves and radio waves are absorbed weakly or not at all. Again, I am not sure how much variation in "colour" would be seen between objects when viewed in microwave, but I would guess very little. As for whether the absorption/emission spectrum of every material is extremely idiosyncratic across all wavelengths, I am fairly sure the answer is no: the absorption/emission spectrum is at generally its most characteristic in the visible part of the spectrum. But, as I say, I am not positive about this. Good question! |
| Aug21-11, 11:03 PM | #6 |
Many thanks for your answers. Especially the "visible spectrum sensitivity" answer I found very revealing, meta. Some follow-up:
espen, I don't understand why you say "yes and no" when you say that the atomic vibrations are mainly responsible for the heat, and not the electron clouds. Or are they the same phenomenon? On the other hand, if it does not get kicked out, the object under light exposure would get ionized very fast (unless the kicked-out electrons will be absorbed by a neighboring ionized atom of the wood immediately thereafter). What gives? For a typical object (say, a piece of wood in direct sunlight), roughly at what frequency does this happen (i.e., an electron is kicked out of an orbital) and roughly what % of the woods surface atoms are affected? From your equation it looks like it would happen way over 99.9% of the objects surface at a extremely high frequency. But what is the approximate mean time for an individual atom from one photoelectric event to the next given typical sunlight exposure? Also, I saw that mass of elementary particles is given in eV. Since when is mass provided in volts? Is this because of e=mc^2? |
| Aug22-11, 03:06 AM | #7 |
| Aug22-11, 05:11 AM | #8 |
Positive and negative infinity are limits, they don't physically exist. Infinities of temperature are a consequence of the integral calculus and entropy, nothing there is really physically infinite either, although some people will tell you they are; I wouldn't believe physics allows for infinities in any energy system though if I was you, only that a number sometimes has peculiarities that reality does not exhibit infinitely.
The energy of lifting a book onto a shelf is really no different that other forms of energy it's just a way to explain context. Energy types are more of a philosophy of kinds than an absolute condition of reality. A way of delineating reactions and interactions. |
| Aug22-11, 09:03 AM | #9 |
| New Reply |
| Thread Tools | |
Similar Threads for: A bunch of basic questions on electrons
| A bunch of LHC relativity questions | Special & General Relativity | 16 | ||
| Bunch of electrons - is it visible? | General Physics | 9 | ||
| Bunch o' Questions | Calculus | 3 | ||
| Bunch of easy Chemistry questions | Chemistry | 2 | ||
| Bunch of questions | Introductory Physics Homework | 17 | ||
