Conversion of Gy/s to Becquerels
  • Context: Medical
  • Thread starter Thread starter Physicsboi
The conversion of Gy/s to Becquerels is feasible but requires specific parameters, particularly the exposure rate constant for the isotope in question, such as Caesium-137. The discussion highlights that a dose rate of 0.7 Gy/s corresponds to 70 rad/s, and the calculation of activity involves the formula: Activity = [70 rad/sec] x [d in m^2] / {[f in rad/R] x [Gamma in R-m^2/Ci-hr]}. Key values include a gamma value of 0.326 R-m²/Ci-hr for unfiltered Cs-137 and an f-factor of approximately 0.96-0.97 rad/R for soft tissue. This method provides an estimate of activity in Ci, which can then be converted to Bq.
  • Understanding of radiation dose measurements, specifically Gy/s and rad/s.
  • Familiarity with Caesium-137 and its properties.
  • Knowledge of exposure rate constants and their significance in radiation calculations.
  • Basic proficiency in unit conversions related to radiation activity.
  • Research the exposure rate constant for various isotopes, focusing on Caesium-137.
  • Learn about the roentgen-to-rad conversion factor and its application in dose calculations.
  • Study the principles of point-source distribution in radiation exposure scenarios.
  • Explore methods for accurately measuring and estimating radiation activity in Bq.
This discussion is beneficial for radiation safety professionals, health physicists, and anyone involved in environmental monitoring or assessing radiation exposure from isotopes like Caesium-137.
Physicsboi
Is it possible to convert Gy/s to Becquerels. I understand that they are a measurement of different things, dose etc. but if it is possible, what further information would I need?
I am trying to find the activity of Caesium- 137, from the Tammiku, Estonia accident. Some of the infromation that has been provided is that it gives
0.7 Gy/s dose.
Biology news on Phys.org
You would need to know the exposure rate constant for your particular isotope (the "gamma"), which also depends on how the isotope was contained (if at all).
You would probably also assume a point-source distribution so you can get at the exposure rate in air at some distance "d" by calculating:
[Exposure Rate] = [Activity] x [Gamma] / d^2
If you multiply this by a factor that converts from exposure in air to absorbed dose in tissue (sometimes called a roentgen-to-rad conversion factor, or f-factor) you can get an approximate dose rate in rad/s. From there converting to Gy/s is a matter of dividing by 100.
So working backwards if you know that the dose rate is 0.7 Gy/s = 70 rad/s, then:
[70 rad/sec] = [Activity] x [f in rad/R] x [Gamma in R-m^2/Ci-hr]/[d in m^2]
"f" is energy and material dependent. For Cs-137 radiation (662 keV) and for dose in soft tissue, it's value is around 0.96-0.97 rad/R.
The number I'm familiar with for the gamma value of unfiltered Cs-137 is 0.326 R-m^2/Ci-hr.
So you would need to take those values (or other published ones you find that you think would be more appropriate) and then do some unit conversions to get everything to cancel, then make a guess on how far the irradiated person was from this point-source approximation of the Cs-137 activity to get "d" and you would have an estimate in Ci. That can then be converted to Bq.
Obviously this is full of approximations and simplifications, but with nothing to go by except for "0.7 Gy/s" it's about the best you can do.
  • · Replies 29 ·
  • · Replies 100 ·
10K
  • · Replies 21 ·
