Can a Vortex Tube be Made Larger for Cooling Purposes?
The discussion centers on the feasibility of constructing a larger vortex tube for cooling purposes, specifically for use in a dorm room. The user, engineeringstudent, proposes using a high airflow fan capable of 6500 CFM to enhance the cooling effect. Expert responses emphasize the importance of applying the first law of thermodynamics to analyze energy transfer within the vortex tube and the fan, noting the low isentropic efficiency of around 30%. The conversation concludes that while a larger vortex tube may provide some cooling, the efficiency and practical implementation must be carefully considered.
  • Understanding of vortex tube thermodynamics
  • Familiarity with the first law of thermodynamics
  • Knowledge of isentropic efficiency concepts
  • Basic principles of airflow and fan performance
  • Research vortex tube design and scaling principles
  • Study the first law of thermodynamics in control volume analysis
  • Explore methods to improve isentropic efficiency in vortex tubes
  • Investigate fan performance metrics and their impact on cooling systems
Engineering students, HVAC professionals, and anyone interested in innovative cooling solutions using vortex tubes and airflow systems.
ENGRstudent1
Alright guys here is the deal, i have had a vortex cooling system on my mind for a while and started wondering
could it be made larger, with more air flowing through it, but with less PSI
and still cool at least somewhat?
i was thinking of making a larger one and attaching it to a high air flow fan in my dorm, as it would not be against the rules of what we can and cannot have, so that i can cool my room kind of like AC
i have a standing fan that i could attach a cone to that in its from factory state moves 6500 cfm
this is the fan i was thinking of using
so, would this even be possible, even if it would drop the temp by 5 degrees (though preferably more)
thanks for any answers
engineeringstudent
PS: i can clarify anything if needed
Science news on Phys.org
Hi ENGRstudent. Welcome to the board. Put a control volume around the vortex tube and consider, is there any heat or work crossing the control surface? What does the control volume look like? Put a control volume around just the vortex tube and ignore the fan for a moment. There is some air with some enthalpy coming into the control volume at one location and some air with some enthalpy leaving the control volume in two different locations. Can you write the first law for this control volume? Is there any heat or work crossing the control surface?
We could also imagine there is something happening within this control volume. There is a transfer of energy between the two discharge streams. A vortex tube is analogous to a device that takes some of the incoming air and expands it (not very efficiently) through one of the two discharge paths. The isentropic efficiency for this path is much less than 100%, probably around 30%. The energy rejected by this discharge path must be put into the second discharge path because of conservation of energy right? Consider that you have to take this warmer air and put it somewhere. Will it go into your dorm room?
You can also put a control volume around just the fan so you have air going into the fan and leaving the fan with some enthalpy and there is also some electric power entering the CV to run the fan. What does that control volume look like? Again, the isentropic compression of the air is much less than 100% efficient. What happens to the air temperature?
Try writing the first law for these two CV's and see if that helps at all. Then look at how you can put the two together and see if there's any way you can get cold air into your room.
  • · Replies 18 ·
