The Inverse Function of f(x)=x^2+x
The discussion revolves around finding the inverse function of f(x) = x^2 + x. Participants express familiarity with the inverse but seek clarification on the method to derive it, particularly through the use of quadratic equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss setting f(x) equal to y and manipulating the equation to express y in terms of x. There is mention of using the quadratic formula to solve for y, as well as exploring the implications of the function being non-invertible in a strict sense due to its nature as a parabola.
Some participants have provided guidance on using the quadratic formula, while others explore the implications of the function's structure. Multiple interpretations of the inverse function are being discussed, particularly regarding the need to consider the function's behavior on either side of its vertex.
There are references to the limitations of expressing the inverse function due to the quadratic nature of f(x), and some participants question the completeness of the quadratic form. Additionally, there are mentions of formatting issues related to mathematical symbols in the discussion.
Badballer
I'm trying to work out the method of getting the inverse function of
[itex]f(x) = x^2 + x[/itex]I already know the inverse but I would like to know the method used to obtain it. So far I have:
Made f(x) = y:
[itex]y = x^2+2[/itex]
And then made y = x and x = y:
[itex]x=y^2+y[/itex]
And then I did this but I'm not sure if it's correct:
[itex]x=y(y+1)[/itex]
Apparently the solution is this
[itex]x(y) = 1/2 (-1±sqrt(4 y+1))[/itex]
But I need to know the steps to get that. Hope you can help. :)
Made f(x) = y:
OK, let's leave from here. What you did afterwards is correct, but it won't help.
You have
[tex]y^2+y-x=0[/tex]
this is a quadratic equation in y, so it can be solved with the quadratic formula. What does that give you?
Oooh right so
a = 1
b = 1
c = -x
[itex]y=-1\pm \sqrt{(1+4x)}/2[/itex]
I think
Also sorry, I really fail with these itex tags.
By the way, since a real valued function of a real variable is "single valued", that does not have a true "inverse". What you are saying is that you can divide it into two functions, on either side of the vertex of the parabola, one having inverse function [itex]f^{-1}(x)= (1/2)(-1+ \sqrt{4x+ 1})[/itex] and the other having inverse [itex]g^{-1}(x)= (1/2)(-1- \sqrt{4x+ 1})[/itex]
try this:
http://www.sosmath.com/algebra/quadraticeq/quadraformula/quadraformula.html
y(x) = a(x^2)+bx+c
0 = a(x^2)+bx+(c-y)
x(y) = (1/2a)(-b+(b^2 - 4a(c-y))^.5)
which is just the general quadratic with c replaced by (c-Y) so that x becomes a function of y. Abel showed this can't be done in general for polynomials with a finite number of arithmatic operations.
I would like to know how to the math symbols in something other than text. Is that what badballer was referring to in "itex tags"?
I do not know the formula, but know the answer. Your function x^2+x looks like not-complete standart quadratic equation
a^2+2ab+b^2
(where a^2=x^2, 2ab=x, but missing b^2),
if it would be complete we could write it as
(a+b)^2.
To make it complete we add missing b^2,
if our a=x and 2ab=x, then our b is 1/2.
Our b^2 is 1/4, so we add it on both sides:
y+1/4=x^2+x+1/4.
y+1/4=(x+1/2)^2.
Square root both sides:
x+1/2=±sqrt(y+1/4)
move 1/2 from left side to right
x=±sqrt(y+1/4)-1/2.
Now you can transform right side of your equation to what you have
x=1/2(±2sqrt(y+1/4)-1).
Put 2 under square root:
x=1/2(±sqrt4(y+1/4)-1)
Then just do simple math
a^2+2ab+b^2
(a+b)^2.
y+1/4=x^2+x+1/4.
y+1/4=(x+1/2)^2.
x+1/2=±sqrt(y+1/4)
x=±sqrt(y+1/4)-1/2.
You have just answered a thread that is more than 1 year old.
  • · Replies 27 ·
