Optimizing Productivity: Linear Programming for All-Easy's Production Goals
The discussion revolves around formulating a linear programming (LP) model for optimizing production goals at All-Easy, which manufactures three products with specified labor and machine time constraints. Participants explore how to incorporate additional costs for exceeding these constraints into the objective function and constraints of the LP model.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the formulation of the LP model, questioning how to adjust the objective function and constraints to account for additional labor and machine costs. There is exploration of the implications of exceeding budgeted hours and how to express these mathematically.
Several participants have provided insights into the formulation of the LP model, suggesting adjustments to the objective function and constraints. There is ongoing exploration of how to represent additional costs and the implications for the model's stability and formal structure.
Participants express concerns about the stability and formal nature of the model, particularly regarding the use of equalities versus inequalities in the constraints. There is a focus on ensuring clarity in variable representation and the relationships between excess hours and costs.
franz32
All-Easy manufactures three products whose unit profits are $1, $9 and $5, respectively. The company has budgeted 70 hrs. of labor time
and 45 hours of machine time for the production of three products.
The labor requirements per unit of products A,B C are 2, 3 and 5 hours, respectively. The corresponding machine time requirements per unit are 1, 4 and 5 hour.
All-Easy regards the budgeted labor and machine hours as goals that must be exceeded, if necessary,but at the additional cost of $15 per labor hour and $5 per machine hour. Formulate the problem as an LP model.
Doubts w/ solutions:
I let x = no. of units of product A, y = no. of units of product B, z = no. of units of product C.
Maximize: z = x + 9y + 5z (profit)
subject to:
2x + 3y + 5z <= 70 (labor hrs.)
x + 4y + 5z <= 45 (machine hrs.)
x,y,z >= 0
"All-Easy regards the budgeted labor and machine hours as goals that must be exceeded, if necessary, but at the additional cost of $15 per labor hour and $5 per machine hour." - if I were to make mathematical model out of these, am i going to adjust my objective function or my constraints or both? How?
Let u = additional labor hours, and v = additional machine hours. How do they affect your profit, and how do they affect your constraint functions? Express it algebraically.
I got this idea... so at least, I can show you where am I... got stuck
We have a constraint on Labor: 2x + 3y + 5z <= 70,
but it can be exceeded ... at extra cost.
If 2x + 3y + 5z is greater than 70, it costs an additional $15/hour.
The excess is: (2x + 3y + 5z - 70) hours which costs $15/hr.
The extra labor cost is: 15(2x + 3y + 5z- 70) dollars,
which, of course, reduces the profit.
Similarly, we have a constraint on Machine time: x + 4y + 5z <= 45
which can be exceeded ... at extra cost.
The excess is (x + 4y + 5z - 45) hours which costs $5/hr.
The extra machine cost is: 5(x + 4y + 5z - 45) dollars,
which also reduces the profit.
is this correct? Can I relate it to what you've replied... and um, that's it, how will I re-formulate my LP model?
OK, but remember that your labor hours are no longer limited to 70.
subject to:
x,y,z >= 0
I would also not use "z" to represent profit, since you are already using it for product C. :)
How about:
Maximize: P = x + 9y + 5z - 5u - 15v (profit)
subject to:
2x + 3y + 5z <= 70 + u (labor hrs.)
x + 4y + 5z <= 45 + v (machine hrs.)
x,y,z,u,v >= 0
And if the goals must be exceeded, you have actual equality:
2x + 3y + 5z = 70 + u (labor hrs.)
x + 4y + 5z = 45 + v (machine hrs.)
Solving for u and v in those get you the two relationships you mention in your post.
Um... I did understand about it... but if I were to write the final part as my model for the LP, it seems that it is "unstable"... bec. I am following the standard form of a LP model...
The final part? you mean the two equalities?
yes.. bec. I don't feel that my model is a formal one yet... =)
The equalities are the bounding surfaces, and the solution is found on the surface--the vertices, in fact.
13K
