(Quantum Mechanics) Infinite Square Well
The discussion revolves around a problem from Griffiths' Introduction to Quantum Mechanics regarding the normalization of a wave function for a particle in an infinite square well. The initial wave function is given as Ψ(x,0) = Ax(a-x), and participants are attempting to find the normalization constant A.
  • Participants discuss the normalization process and the integral required to find A. Some express confusion over the differences in normalization constants for different wave functions, particularly comparing the given function to the sine function used in other contexts.
  • There is also a related inquiry about proving a property of orthogonality for wave functions, with participants questioning the limits of integration and the implications of extending those limits beyond the defined range of the wave functions.
The conversation is ongoing, with participants clarifying misunderstandings about the problem setup and the appropriate limits for integration. Some guidance has been provided regarding the differences in wave functions and their normalization, but no consensus has been reached on the specific normalization constant for the initial wave function.
Participants note that the wave function is defined only within the range of 0 to a, and there is acknowledgment of the need to adhere to this constraint when performing integrations. The discussion highlights the importance of recognizing the specific conditions of the problem being addressed.
emol1414
Hi, I'm stuck in this Griffiths' Introduction to QM problem (#2.8)
A particle in the infinite square well has the initial wave function
[itex]\Psi(x,0) = Ax(a-x)[/itex]
Normalize [itex]\Psi(x,0)[/itex]
[itex]\int_{0}^{a} |\Psi(x)|^2 dx = 1[/itex]
Haha, this is supposed to be the least of my problems but... doing
[itex]A^2 \int_{0}^{a} x^2 (a-x)^2 dx = 1[/itex]
gives us [itex]A = \sqrt{\frac{30}{a^5}}[/itex].
When the correct answer is [itex]A = \sqrt{\frac{2}{a}}[/itex]. I have no clue what I did wrong...
The normalization constant A = sqrt(2/a) is appropriate for ψ(x) = A sin(nπx/a). Here you have ψ(x) = Ax(a-x). Different wavefunctions have different normalization constants.
Kuruman... indeed [itex]A = \sqrt{\frac{2}{a}}[/itex] is appropriate for [itex]\psi[/itex] as a sin function. But when checking the result i got, i found this solution for the exact same problem:
http://img714.imageshack.us/img714/6186/64732846.jpg
The integral limit is set to 0,a/2... I'm not sure why, and if this is correct. For now i'll stick with my solution
_____________________________________________________________________________
By the way... (a correlated problem) trying to prove that: [itex]\int_{-\infty}^{\infty} \psi_n^*(x) \psi_m (x) dx = \delta_{n,m}[/itex] (Kronecker delta).
For n = m, and [itex]\psi_n (x) = \sqrt{\frac{2}{a}} sin(\frac{n \pi x}{a}),\in \Re[/itex], I'm coming up with
[itex]\int_{-\infty}^{\infty} \psi_{n}^{2}(x) dx[/itex] = [itex]\frac{-1}{a} cos(\frac{n\pi x}{a}) sin(\frac{n\pi x}{a})|_{-\infty}^{\infty} + \frac{1}{a} \int_{-\infty}^{\infty} dx[/itex]
The first term goes to 0, but the second would result in 1 for like... [itex]\int_{0}^{a}[/itex], not [itex]\int_{-\infty}^{\infty}[/itex]. Again... where am I messing up?
It is not the exact same problem. The problem above has yet a third wavefunction that is constant for 0≤x≤a/2 and zero everywhere else. That is the reason why the upper limit is set at a/2. If you extend the integral beyond a/2, you will be adding a whole bunch of zeroes since ψ(x) is zero, so you might as well use a/2 for the upper limit.
Here I assume that you are using particle-in-the-box wavefunctions. All of them are zero for x≤0 and x≥a. What do you think your limits of integration ought to be?
Hmm, ok! So it's a different problem
It makes sense now, I forgot the conditions... You're right, it is [itex]\int_{0}^{a}[/itex]!
Thank you
  • · Replies 39 ·
16K
