Proving Electric Flux Using a Spherical Gaussian Surface | E&M Class Problem
The discussion revolves around a proof problem in an Electricity and Magnetism (E&M) class involving electric flux through a disk positioned above a point charge. The original poster is tasked with demonstrating a relationship between the radius of the disk and its distance from the charge, using a spherical Gaussian surface.
  • The original poster considers using a spherical Gaussian surface and questions how to position it relative to the disk. They express confusion about the electric field lines' orientation and whether calculus or geometry is more applicable to the problem.
  • Some participants suggest that the problem is primarily geometric and discuss the surface area of a dome-shaped Gaussian surface.
  • There are inquiries about the complexity of the solution and whether simpler methods exist, including the use of specific formulas for surface area.
Participants are exploring different geometric interpretations and discussing relevant formulas. Some guidance has been offered regarding the use of surface area calculations, but there is no explicit consensus on the approach to take. The conversation reflects a mix of uncertainty and the sharing of insights.
There is mention of the original poster's prior knowledge and the complexity of the mathematical tools they are considering, including double integrals and polar coordinates. The discussion also touches on the availability of resources for further geometric understanding.
Will
This is a proof type problem from our E&M class. We are given a point charge Q, let say that it is at the origin. We then have a disk parallel to the xy plane, with center a distance b from the origin( on the z axis) & radius R. We are to prove that if 1/4 of the flux passes thru the disk, prove that R= [(3)^.5]*b.
I assume that I have to use a spherical gaussian surface with 1/4 of its area corresponding to the size of the disk. Thats where I am confused. Do I make the top of the sphere just touch the bottom of the disk and have radius b, or do I construct it over the top of the disk, like a dome? And how do I acount for the fact that the electric field lines won't be perpendicular to the surface of the disk because it is not round? Will this problem involve calculus, or is more of a geometry type problem?
Hi Will,
I think it's a purely geometrical problem. If you construct a spherical dome over the top of the disc, then the dome's surface should equal 1/4 of the full sphere's.
Thats what I concluded myself. So how do I solve for the radius of the disk in terms of its distance from Q? I was trying to reveiw double integrals in polar coordinates fo SA, does it need to be that complex? Am I missing something simple here?
No. You could use the formula S = 2[pi]*r*h, where
S = surface area of dome,
r = radius of sphere,
h = height of dome.
Just find out how to express r and h in terms of R and b (which is easy), and there you are. OK?
So if one hase a sphere inside a cylindrical shell with equal radius and height 2r, then for any horizantal slice, parts of shell and sphere will have the same SA? Cant believe I did two years calc. and don't know that! Even looked thru a bunch of my old texts and did not see a formula like that written anywhere. Makes sense visually, and the problem became much simpler. thanks
But if I did do all that double integral-ly type stuff, I should get the same answer right?
So if one hase a sphere inside a cylindrical shell [...]
Yes. Geographers use this to construct world maps, see here:
http://mathworld.wolfram.com/CylindricalEqual-AreaProjection.html
There's a lot more formulae like this about spheres. Saves you a lot of time if you own some proper mathematical handbooks.
I'm sure you will.
Well, I don't feel so bad about not knowing this. I went to my old teacher for DFQ's and even he was scratching his head saying he didnt think so! So where can I get a handbook with a extensive collection of geometry stuff than my textbook? I head Shaums outlines are good.
