Solving Bernoulli's Principle Problem: Flow Rate in Horizontal Pipes
The discussion focuses on solving a Bernoulli's principle problem involving flow rates in horizontal pipes with diameters of 11.6 cm and 4.72 cm. The pressures in the larger and smaller pipes are 8.1E4 Pa and 6.82E4 Pa, respectively. To find the flow rate, the continuity equation (A1v1 = A2v2) is applied alongside Bernoulli's principle, resulting in a calculated flow rate of 0.14 m³/s in the larger pipe. The density of water is assumed to be 1000 kg/m³ for the calculations.
  • Understanding of Bernoulli's principle
  • Knowledge of the continuity equation in fluid dynamics
  • Ability to calculate cross-sectional areas of pipes
  • Familiarity with basic fluid mechanics concepts
  • Learn how to derive the continuity equation in fluid dynamics
  • Study applications of Bernoulli's principle in real-world scenarios
  • Explore the relationship between pressure and flow rate in different pipe systems
  • Investigate the effects of pipe diameter changes on fluid velocity
Students studying fluid mechanics, engineers working with fluid systems, and anyone interested in applying Bernoulli's principle to practical problems in hydraulics.
Cyrad2
Hi! This is the first question on my homework, so it's suppost to be the easiest, but I'm not sure how to tackle it. It's a Bernoulli's principle problem. Here it is:
A horizontal pipe 11.6 cm in diameter has a smooth reduction to a pipe 4.72 cm in diameter. If the pressure of the water in the larger pipe is 8.1E4 Pa and the 6.82E4 Pa pressure in the smaller pipe is at what rate does water flow through the pipes?
So I thought I'd use the equation:
P1 + .5pv1^2+pgy1 = P2 + .5pv2^2+pgy2
I'm not sure how to apply this to my problem because the equation has two unknowns: v1 and v2. Is there another bernoulli's equation i should be using?? There are several variations in my text, but none seem to work. Thanks, Brad
equation of continuity
You need to apply the continuity equation, which says that the same amount of mass flows past each point. It can be written as [itex]A_1 v_1 = A_2 v_2[/itex], where A is the cross-sectional area.
Hi Brad,
To solve this problem, you can use the continuity equation in addition to Bernoulli's principle. The continuity equation states that the flow rate (Q) is equal at any two points in a fluid system, so:
Q1 = Q2
Where Q1 is the flow rate in the larger pipe and Q2 is the flow rate in the smaller pipe.
Using this equation, we can set up a ratio between the two flow rates:
Q1/Q2 = A2/A1
Where A1 and A2 are the cross-sectional areas of the larger and smaller pipes, respectively.
We can rearrange this equation to solve for Q1:
Q1 = Q2 * (A1/A2)
Substituting in the values given in the problem, we get:
Q1 = Q2 * (11.6 cm/4.72 cm)^2
Now, we can use Bernoulli's principle to solve for the flow rate in the smaller pipe (Q2). Setting up the equation with the given pressures and using the fact that the pipes are horizontal (y1 = y2), we get:
8.1E4 Pa + 0.5pv1^2 = 6.82E4 Pa + 0.5pv2^2
Solving for v2, we get:
v2 = √(2*(8.1E4 Pa - 6.82E4 Pa)/p)
Where p is the density of water (1000 kg/m^3).
Now, we can plug this value into our equation for Q1:
Q1 = (1000 kg/m^3 * √(2*(8.1E4 Pa - 6.82E4 Pa)/1000 kg/m^3)) * (11.6 cm/4.72 cm)^2
Simplifying, we get:
Q1 = 0.14 m^3/s
So, the rate of flow in the larger pipe is 0.14 m^3/s. I hope this helps! Let me know if you have any further questions.
  • · Replies 16 ·
  • · Replies 16 ·
