New Reply
Boiling point and vapor pressure
Share Thread Thread Tools
Aug25-11, 03:29 PM   #1
I am trying to understand the concept of boiling from a very fundamental perspective. Most textbooks say that: as a liquid is heated, it's vapor pressure increases. When the vapor pressure reaches the surrounding pressure(or atmospheric pressure at that point), then boiling occurs.
I agree with the above point.
My question is: when the vapor pressure reaches the surrounding pressure, what physically happens that allows vapor to form all through the liquid for it to boil.
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Aug25-11, 03:40 PM   #2
Mentor
Pressure is what prevents a volume of water from spontaneously flashing into steam - be it air pressure above or water pressure around it. If a volume of water gets hot enough that it "wants" to be steam at a certain pressure and the pressure around it is lower than that, it will spontaneously flash to steam.
Aug25-11, 04:00 PM   #3
Thank you for your reply.
So if the vapor pressure reaches the surrounding atmospheric pressure, how does that lead to the pressure around the volume of water being lower than the pressure with which the steam wants to form?
By "wants", do you mean that the molecules break away from surrounding molecules by absorbing the latent heat?
New Reply
Thread Tools
Similar Threads for: Boiling point and vapor pressure
Thread Forum Replies
Vapor pressure, its decrease and subsequent lowering of boiling point Classical Physics 9
Boiling point and vapor pressure General Physics 1
Using boiling temperature as a proxy for vapor pressure Chemistry 1
Boiling point at a certain pressure! Classical Physics 0
Finding normal boiling point given pressure and enthalpy. Biology, Chemistry & Other Homework 4
