Man & Woman Separating at 10 sec: A Bridge View
  • Context: Undergrad
  • Thread starter Thread starter cowgiljl
    Bridge
The separation rate between a woman walking at 6 ft/sec across a bridge and a man in a boat moving at 4 ft/sec is calculated using the Pythagorean theorem. After 10 seconds, the distance between them increases at a rate of 13.87 ft/sec. The height of the bridge, 40 ft, does not affect the separation rate since it remains constant. The calculation involves differentiating the distance formula with respect to time, confirming the correctness of the approach taken.
  • Understanding of Pythagorean theorem in three dimensions
  • Knowledge of implicit differentiation techniques
  • Familiarity with rates of change in calculus
  • Basic concepts of relative motion
  • Study the application of implicit differentiation in physics problems
  • Learn more about relative motion and its implications in real-world scenarios
  • Explore the use of the Pythagorean theorem in three-dimensional space
  • Investigate calculus applications in motion analysis
Students and professionals in mathematics, physics, and engineering fields who are interested in understanding rates of change and relative motion in dynamic systems.
cowgiljl
a women is walking at a rate of 6 ft/sec across a bridge 40 ft above the water, a man in a boat is immediately below the woman on the bridge , at right angles to the bridge and at the rate of 4 ft /sec. how fast is the man and woman seprating at the end of 10 seconds
what i have figured out is the 2 deminationally not including the 40 ft
dx/dt = 6ft/sec dy/dt = 4 ft/sec dz/dt = ?
z^2 = x^2 + y^2 z = sq root 52 = 7.21
using implicate differenating dz/dt = 1/z (x(dx/dt) + y(dy/dt))
dz/dt = 1/7.21(4(10) +6(10)
= 100 / 7.21
= 13.87 ft/sec
I can drw it diagram but not sure what to do for the 40 ft
thanks joe
The rate of change of the distanceis found as follows:
The position of the woman relative to the man in the boat is:
[tex]\vec{r}(t)=6t\vec{i}+4t\vec{j}+40\vec{k}[/tex]
The distance between them r(t), is given by the Pythagorean theorem:
[tex]r(t)=\sqrt{36t^{2}+16t^{2}+1600}[/tex]
The separation velocity is now given as [tex]\frac{dr}{dt}[/tex]
Your calculations are correct. The 40 ft height of the bridge does not affect the separation rate of the man and woman, as it is a constant distance between them. The only variables that affect the separation rate are the horizontal distances (x and y) and their respective rates (dx/dt and dy/dt).
To visualize this situation, you can imagine the woman walking at a constant speed across the bridge, while the man in the boat is moving at a right angle to her path. As time passes, the distance between them increases due to their different rates of movement. By finding the rate of change of the distance between them, you have determined the separation rate at that given moment.
Overall, your answer is correct and well-explained. Keep up the good work!
12K
