Inverse square & cube laws for various geometries
The discussion focuses on the inverse-exponent force magnitude fall-off laws for monopole and dipole materials in various geometries. It establishes that the far-field force for monopole-based objects follows a 1/r² relationship, while dipole-based objects exhibit a 1/r⁴ relationship. The near-field force calculations for specific geometries, such as a point near a line and lines near each other, are derived using dimensionality arguments. The conclusions clarify that the force between two line charges is independent of distance, represented as λλ/r⁰.
  • Understanding of monopole and dipole concepts in physics
  • Familiarity with dimensional analysis techniques
  • Knowledge of electrostatics, specifically point charges and line charges
  • Basic grasp of force relationships in physics
  • Research the mathematical derivation of force laws for monopoles and dipoles
  • Explore the implications of dimensionality arguments in physics
  • Study the behavior of electric fields generated by line charges
  • Investigate the applications of inverse square and cube laws in real-world scenarios
Physicists, engineering students, and anyone interested in the theoretical foundations of force interactions in electrostatics, particularly those studying monopole and dipole systems.
fleem
I would like to compile a short list of inverse-exponent force magnitude fall-off laws for several simple geometries for material made of monopoles and for material made of parallel dipoles (of negligible length).
Far field force for any two objects is, of course, proportional to [itex]1/r^2[/itex] for monopole-based objects, and [itex]1/r^4[/itex] for dipole-based objects (yes, field for dipoles drops with [itex]1/r^3[/itex], but I'm interested in force between two objects that are both made of dipoles. The definition for field strength is related to the force on a monopole).
So what is the force magnitude fall-off (both monopole and dipole material) for the following near-field geometries?:
a point near a line
a line near a parallel line
a line near a perpendicular line
(Side note: the field above a plane made of dipoles is uniform, so there will be zero force (except torque) on dipoles above it)
Thanks.
fleem, You can figure out things like this using just dimensionality arguments. For two point charges the force is QQ/r2. Now a dipole moment is P ~ Qd, so the force must be?
Ans: The P's give you two more lengths in the numerator, so the force must be PP/r4
A line charge works the other way: λ = charge per unit length, and the force between two line charges is λλ/r??
Ans: You now have two lengths less in the numerator, so the force must be λλ/r0, i.e. independent of r.
Good grief I didn't even think of doing that. Thank you! This answers all my questions.
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 24 ·
