On the average, a blink lasts about 100ms
  • Context: Undergrad
  • Thread starter Thread starter ajbryant
    Average
The average duration of a blink is approximately 100 milliseconds. During this time, a MiG-25 Foxbat, traveling at an average velocity of 2500 miles per hour, covers a distance of 69.4 feet. In a separate scenario, a car moving at a steady velocity of 115 km/h for 115 seconds experiences zero acceleration, as acceleration is defined as the rate of change of velocity. Additionally, when calculating distance using the formula d = 1/2at² for a car accelerating from 0 to 30 m/s in 14 seconds, understanding the variables involved is crucial for accurate results.
  • Understanding of basic physics concepts such as velocity and acceleration
  • Familiarity with the formula d = 1/2at² for distance calculation
  • Knowledge of unit conversions between miles, kilometers, and meters
  • Ability to interpret and apply equations related to motion
  • Study the principles of kinematics in physics
  • Learn about unit conversions for speed and distance
  • Explore the concept of acceleration and its calculation
  • Review the derivation and application of the equation d = 1/2at²
This discussion is beneficial for physics students, educators, and anyone interested in understanding motion dynamics and the relationship between velocity, acceleration, and distance.
ajbryant
on the average, a blink lasts about 100ms. how far does a MiG-25 foxbat fighter travels during a pilot blink if the plane average velocity is 2500mi/h. my answer is 69.4
what is the acceleration of a car that moves at a steady velocity of 115 km/h for 115 seconds? my answer is 115km/h. the explanation of this answer is b/c the steady velocity of the acceleration of the car is going in the same of 115km/h as it is in 115 sec.
a car takes 14s to go from v=0 to v=30m/s at approximately constant acceleration. if you wish to find the distance traveled using the equation d = 1/2at^2, what value should you use for a?
2500 mph / 3600 (seconds per hour) = .6944444
one tenth of that is about 1/16 of a mile in a tenth of a second.
Steady velocity means no acceleration, (it would have to be traveling straight technically speaking)
a= (v2-v1)/(t2-t1)
or, the change in velocity over the change in time
"my answer is 69.4"
69.4 WHAT? Your answer doesn't make sense without units: miles?, feet?, meters? and thinking about how the units match up might help you see how to get the answer.
"what is the acceleration of a car that moves at a steady velocity of 115 km/h for 115 seconds?"
Are you sure you have copied the question correctly? At a minimum you should know that "acceleration" MEANS the rate at which velocity is CHANGING. If the car "moves at a steady velocity" then the acceleration is 0.
"my answer is 115km/h. the explanation of this answer is b/c the steady velocity of the acceleration of the car is going in the same of 115km/h as it is in 115 sec."
Once again, check your units. Acceleration is km/h2, not km/h. Understanding that may help. By the way, "the steady velocity of the acceleration" makes no sense at all!
"a car takes 14s to go from v=0 to v=30m/s at approximately constant acceleration. if you wish to find the distance traveled using the equation d = 1/2at^2, what value should you use for a?"
WHY should you use that formula. It is NEVER a good idea to use a formula that you don't understand. When you learned the formula you should have learned what "d", "a", and "t" MEANT. Knowing that, the answer is easy.
  • · Replies 18 ·
9K
  • · Replies 19 ·
21K
