Impulse and Momentum of a falling student
The discussion revolves around two physics problems related to impulse and momentum. The first problem involves a student falling from a height and the forces acting upon him during the collision with the ground. The second problem concerns a projectile passing through a wooden block and the resulting velocities of both objects.
  • Mixed
  • Participants discuss the application of impulse and momentum principles to both problems. There are attempts to derive the height from which the student fell using impulse and energy conservation, as well as to analyze the momentum transfer in the projectile-block interaction. Questions arise regarding the correctness of the provided answers and assumptions about the block's mass post-collision.
The discussion includes various approaches to solving the problems, with some participants providing guidance on how to apply relevant physics concepts. There is a lack of consensus on the correctness of the original poster's answers, and some participants express doubt about the assumptions made in the problems.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a noted concern about the physical implications of the projectile's interaction with the block.
Bcisewski
Can anyone assist, I have tried various formulas on both problems with no luck. Thanks for any assistance or feedback.
1) A student (m = 59 kg) falls freely from rest and strikes the ground. During the collision with the ground, he comes to rest in a time of 0.020 s. The average force exerted on him by the ground is +21000 N. From what height did the student fall? Assume that the only force acting on him during the collision is that due to the ground. The answer should be 2.59m
2) A 0.295-kg projectile is fired with a velocity of +585 m/s at a 1.00-kg wooden block that rests on a frictionless table. The velocity of the block, immediately after the projectile passes through it, is +40.4 m/s. Find the velocity with which the projectile exits from the block. The answer should be 352.19 m/s
Please show what work you have done. Here's how you should be approaching these:
1: -Find the student's velocity just before he hits the ground (use the idea that the impulse is equal to the change in momentum and realize that the student's velocity is 0 immediately after the collision (we'll assume he doesn't bounce)).
-Next, use this velocity to find the initial height. You can use the conservation of energy or the kinematic equations you learned for contant acceleration motion.
2. - This is a straight application of the conservation of momentum. Initially, only the bullet has the momentum. After the bullet passes through the block, both the block and the bullet have momentum:
[tex]m_bv_{bi} = m_bv_{bf} + m_Bv_{Bf}[/tex]
(b = bullet; B = Block; i = initial; f = final)
I believe the number you gave for what "should" be the answer is incorrect.
I also think that your official answer for 2) is wrong.
Use: [itex]mgh = 1/2mv^2[/itex] so [itex]v = \sqrt{2gh}[/itex]
Since [itex]F\triangle t = mv[/itex] we have:
[tex]h = F^2t^2/2gm^2[/tex]
[tex]h = 2.59 m.[/tex]
The answer should be 448.05 m/s. The real question is why we should assume that the wood block still has a mass of 1 kg after the projectile passes through it. A .295 kg projectile is a small canonball that would make a huge hole in the block if not destroy it. :smile:
AM
  • · Replies 31 ·
  • · Replies 19 ·
9K
