What Is the Minimum Power Required for a Heat Pump to Maintain 20°C?
The minimum power required for a heat pump to maintain a house at 20°C with a heating load of 10kW and an outside temperature of -5°C is calculated using the formula for the Coefficient of Performance (COP). The COP is determined by the temperatures involved, yielding a COP of approximately 11.73. Consequently, the minimum power needed to drive the heat pump is 0.85 kW, ensuring efficient heating under specified conditions.
  • Understanding of thermodynamics, specifically the principles of heat transfer.
  • Familiarity with the Coefficient of Performance (COP) in heat pump systems.
  • Basic knowledge of heating load calculations.
  • Awareness of temperature conversion between Celsius and Kelvin.
  • Research the principles of heat pump efficiency and COP calculations.
  • Explore different types of heat pumps and their applications in residential heating.
  • Learn about the impact of external temperatures on heat pump performance.
  • Investigate advanced heating load calculation methods for energy-efficient home design.
Homeowners, HVAC engineers, energy efficiency consultants, and anyone involved in residential heating system design and optimization.
samirnasri
Hello,
Just wondering if you could help me out with this question;
A house is to be maintained at 20°C in winter and the heating load is 10kW. The
outside temperature is -5°C. If a heat pump is to be used to heat the house,
what is the minimum power required to drive the heat pump?
Would it be
273.15+20 / 25 = 11.73
10 / 11.73 = 0.85 kw?
You get an A+.
The + is for brevity.
  • · Replies 23 ·
  • · Replies 18 ·
