Why is my transformerless converter unit failing?
The discussion revolves around the construction and troubleshooting of a transformerless converter unit designed to convert 240V AC to 12V DC. Participants explore the technical challenges faced by a beginner in electronics, particularly regarding voltage measurements and safety concerns associated with high voltage circuits.
  • Homework-related
  • One participant notes that the 14.59V measured is the RMS value without filtering, suggesting that the average DC voltage increases to nearly the peak value after adding a capacitor.
  • Another participant expresses concern about the safety of working with 240V AC in a non-isolated setup and questions the builder's understanding of the circuit.
  • A participant recommends using an oscilloscope to check waveforms and emphasizes the importance of isolation transformers for safety.
  • Some participants question the necessity of a non-isolated power supply and suggest alternatives like using a wall-wart for the 12V output.
  • There is a request for the builder to provide more information about their background and the purpose of the circuit, highlighting the potential dangers involved.
Participants generally agree on the safety risks associated with the project and the need for proper equipment and understanding. However, there are differing views on the necessity of a non-isolated power supply versus using a standard power supply.
Participants express concerns about the builder's experience level and the safety measures in place for working with AC mains power. There are unresolved questions about the specific circuit connections and the implications of using a zener diode in the setup.
This discussion may be useful for beginners in electronics, particularly those interested in power supply design and safety considerations when working with high voltage circuits.
adefilaedward
Hi all, I'm trying to build a transformerless converter unit, that will take an input of 240v a.c, and will output 12v d.c. I used a voltage divider to get a 16v from the a.c supply of 240v and connected my rectifying circuit across the 16v. I got an output of 14.59v. But on connecting the capacitor, the voltage went up to 22v. WHY? Another thing is that, on connecting the zener diode, i was unable to get any reading. I'm confused.
14.59 v is the rms value that you measured without a filter, since there is a ripple in the signal.
After you place a capacitor, the average dc voltage increases to almost the peak value, then v = sqrt(2)*14.59 = 20 v
Zener diode should be connected between the output voltage and the ground, show your connection.
Welcome to the PF.
What you are doing sounds quite dangerous. Your are working with 240Vac, non-isolated, and you do not seem to understand what you are doing.
Can you please tell us about your background and training? And why are you building this circuit? What safety measures are you building into this AC Mains powered, non-isolated power supply? What is the application?
i'm a student. A beginner. I want to use the circuit to power a relay, part of an experiment.
You really need an oscilloscope. Add one part at a time, checking your waveforms with each addition. Isolation transformers are always good because it keeps 240VAC from "electricfying" the case of the converter you are building. 240VAC both leads are typically "hot."
This is a very dangerous circuit for you to be trying to build as a beginner. As dink says, you really need an isolation transformer to keep your output circuit more safe. Why do you want to use a non-isolated power supply? Can't you just use a regular power supply to power your relay?
Do you have a faculty advisor overseeing this work? Is he/she familiar with AC Mains safety?
If you go to measure with a scope, don't forget that most scopes have their signal grounds connected to protective Earth - touching a live circuit can do very bad things.
I'm with Berkeman though - you don't sound very experienced. If you absolutely don't need a non-isolated power supply, you could just use a wall-wart to get your 12V until you can have somebody experienced help guide you. Don't take this as a personal attack, we all have to start somewhere.
  • · Replies 21 ·
