Positive Root Solutions for Quadratic Equations with Variable Coefficients
  • Thread starter Thread starter Sumedh
    Roots
The discussion focuses on determining the values of α for which the quadratic equation 4x² - 4(α-2)x + (α-2) = 0 has both roots positive. The conditions derived include a non-negative discriminant (D ≥ 0), leading to α being in the intervals (-∞, 2] and [3, ∞), and ensuring the function value at zero is non-negative (f(0) ≥ 0), resulting in α being in the interval (2, ∞). The final solution requires confirming the conditions for the vertex of the parabola, represented by -b/2a, to be greater than zero.
  • Understanding of quadratic equations and their standard form
  • Knowledge of the discriminant and its implications for root nature
  • Familiarity with vertex form of a quadratic function
  • Basic algebraic manipulation skills
  • Study the properties of the discriminant in quadratic equations
  • Learn about the vertex of a parabola and its significance in root analysis
  • Explore the implications of function values at specific points for root positivity
  • Investigate the behavior of quadratic functions with variable coefficients
Students studying algebra, particularly those focusing on quadratic equations, mathematicians analyzing root conditions, and educators teaching polynomial functions.
Sumedh
[SOLVED]
Let[tex]4x^2-4(α-2)xα-2=0 (α\epsilon R)[/tex]
be a quadratic equation, then find the value of α for which both the roots are positive.
the conditions will be
1) Discriminant D≥0
by this condition i got α (-∞,2][3,∞)
2) f(0) greater than or equal to 0
by this we get α (2,∞)
3) now should i use -b/2a(point exactly between both roots)
and equate as -b/2a greater than 0if-3rd point is right then what will be the final answer
α (?,?)union(?,?)
please provide help
1) Discriminant D≥0
α (?,?)union(?,?)
please provide help
Are you sure the equation has typed up correctly? hopefully there should be a + or - sign between the x and the alpha??
Thanks,
I have solved the problem:smile:
there is a + sign.
  • · Replies 22 ·
  • · Replies 20 ·
