Lift Problem involving forces, acceleration and speed
The discussion centers on a physics problem involving a lift in a mine shaft that descends 500 meters in one minute, starting from rest, accelerating uniformly for 12.5 seconds, maintaining a constant speed, and then decelerating to a stop. The lift has a mass of 5 tonnes and carries 12 miners averaging 80 kg each. The tension in the cable during the acceleration phase is 53,640 N, resulting in an acceleration of 0.8 m/s². The time spent traveling at constant speed is determined to be 40 seconds, with a final deceleration of 1.33 m/s².
  • Understanding of Newton's second law (mg-T=ma)
  • Knowledge of kinematic equations for uniformly accelerated motion
  • Familiarity with speed-time graphs
  • Basic algebra for solving equations
  • Study the derivation of kinematic equations for uniformly accelerated motion
  • Learn how to analyze speed-time graphs for motion problems
  • Explore the concept of tension in cables and its effects on acceleration
  • Practice solving similar physics problems involving forces and motion
Students studying physics, particularly those tackling problems related to forces, motion, and kinematics, as well as educators looking for practical examples to illustrate these concepts.
Pho3nix
A Lift in a mine shaft takes exactly one minute to descend 500m. It starts from rest , accelerates uniformly for 12.5 seconds to a constant speed which it maintains for some time and then decelerates uniformly to stop at the bottom of the shaft.
The mass of the lift is 5 tonnes and on the day in question it is carrying 12 miners whose average mass is 80 kg.
(i) Sketch the speed-time graph of the lift.
During the first stage of the motion the tension in the cable is 53 640 N
(ii) Find the acceleration of the lift during this stage.
(iii) Find the length of time for which the lift is traveling at constant speed and the final deceleration.
mg-T=ma
Positive down
g=9.8m/s^2
(i) Don't know how to get a graph up so i'll just describe it; a linear increase in speed from rest for 12.5s. Then a horizontal line representing a constant speed from some time. After that, a deceleration at an unknown time producing a linear decrease in speed to rest, at 60s.
(ii) (5000+80*12)g - T = (5000+80*12)a
a=0.8m/s^2
(iii) This is the part I can't do. I don't know where to start without any information on the time or distance at the start of deceleration. The answer I get from the back of the book is 40s and 1.33m/s^2.
About the graph -
right.About the second part -good job.
The third part is indeed a little harder.
As I've said, you can find the final speed of segment 1, up until the lift doesn't accelerate.
You can calculate the distance the lift passed in this first segment.
Call "t" the time in which the lift moves with a constant velocity. What is the distance (as a function of t) the lift passes at segment two?
From the data you've given, you know now the distance of segment 3 (as a function of t) and the time of segment 3 (as a function of t). You also know the initial velocity and the final one (0). Use this information and 2 formulas relating the distance, time, acceleration and velocities to get your acceleration and time. These are two variables with two equations.
Good luck!
Ty for your response and hints to part 3. I've worked out part 3 using the speed-time graph (which I guess the question was hinting at) and it's quite simple, which fits in with a small part 3 question in an M1 book.
I used area=half base times height. Solving for the top side gives 40s; the time the lift was traveling at constant speed. The rest can be worked out easily.
EDIT: My bad, its area = 1/2(base+a)*maxv
