Can't Solve This Rigid Solid Problem? Let's Figure It Out!
  • Thread starter Thread starter Feynmanfan
    Figure Solid
The discussion revolves around a rigid solid problem involving a rod suspended by a string, where participants explore the dynamics of oscillation and the relationship between the rod and the string during motion. The original poster seeks to understand why the rod and string cannot align in the same direction throughout the oscillation process.
  • The original poster attempts to prove the impossibility of the rod and string being in the same direction by seeking contradictions in their motion. Participants question the initial conditions of the system and suggest considering the effects of oscillation on the rod's behavior.
Participants are actively engaging with the original poster's question, providing hints and prompting further clarification. There is a focus on understanding the underlying principles of rigid body motion and the implications of initial conditions on the system's behavior.
The discussion includes considerations of external forces, specifically gravity, and the properties of rigid bodies in motion. There is an acknowledgment of the complexities involved in analyzing the system's dynamics and the potential for observable effects during oscillation.
Feynmanfan
I don't know how to solve this rigid solid problem
Let there be a rod hanging of a string fixed to a certain point. Why is not possible for both the string and the rod to be in the same direction all the time. (it is common sense that it's impossible but how can I prove it?)
I've tried to figure it out thinking that it is possible and look for a contradiction.
Thanks a lot!
Can you make your question clearer?
I'm sorry for not explaining myself clearer. the string is attached to the rod at the center of one of its ends, no external forces are acting on it other then gravity. The thing is that the rod will start oscillating and I want to prove that it is impossible that both the rod and the string stay in the same direction (as if it were a single rod).
What properties of the rigid solid should I use to prove it is impossible?
Thanks again
Well, it all depends on how you start it oscillating, of course (what is the initial position of the rod and string and so forth). But one thing that might be more intuitive to think about is this - how about if you had the rigid rod _above_ the string, what would the end of the string do as the rod swung to and fro?
A further hint: the tangential acceleration at every point along a pendulum system is the same (ma=mgsinx, so the ms cancel out). Rigid bodies swing all in one line because of internal attractive forces among their constituent atoms that "drag" each other along each other - what if the forces were weaker? If every point in the string-rod system was accelerating the same, would the system remain a straight line?
Actually, in what you're proposing, the observable effect would be miniscule because tension would work to keep the system fairly straight (assuming the rod was significantly heavier than the string). You _would_ observe a "kink" if you looked hard enough, though.
Btw, it'd probably be useful to think some more about why ideal rigid bodies fall as a straight line in pendulum motion - that is, why the center of mass concept works. (edit: ahh, which is not to imply it doesn't work for non-rigid bodies; what i meant to say is: why the center of mass concept is so useful for examining a physical pendulum)
11K
