Why Is public static void main(String[] args) Essential in Java Programs?
  • Context: Java
  • Thread starter Thread starter heman
    Java
The discussion centers around the significance of the line "public static void main(String[] args)" in Java programs, particularly its components and their roles. Participants explore the importance of this line for program execution and its implications for beginners learning Java.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant notes that "main" is the function from which program execution starts, and "void" indicates that it does not return a value.
  • Another participant suggests that while the significance of "public static" may not be clear to beginners, "String[] args" serves as arguments that can control program behavior.
  • A further contribution emphasizes that the presence of the "main()" method is what makes a Java class runnable, and without it, the compiler will produce a NoSuchMethodException.
  • It is mentioned that applets do not require a "main()" method, as execution can start with the "init()" or "paint()" methods instead.
Participants generally agree on the essential role of the "main()" method for executing Java programs, but there are varying levels of understanding regarding the components of the line and their implications for program behavior.
Some participants express uncertainty about the significance of "public" and "static" in the context of Java classes, indicating a need for further clarification as they progress in their learning.
heman
As a very beginner to java a very basic question is in mind.in every java program we write the first line after mentioning the name of the class as
____________________________________
_____________________________________
so i want to know the importance of this line and each component in this line because i am not getting to it.
i will be very thankful for urs help.
Technology news on Phys.org
Main is the function from which program execution stars.void implies that the function doesn't return a value.The rest you can put off until later.public(after learning classes)statis(types of variables)
Since you're beginning, you may not understand the significance of the "public static," but the String[] args may be useful to know. Those are some arugments to control how your program works.
Say you have a class "Circle." that looks something like this:
public class Circle
drawCircle(args[0]);
void drawCircle(String a){...} //would contain code for drawing a circle of a certain color.
Upon calling your program, you'd need to tell the program what color you wanted. You would, for example, call "Circle blue," and it would draw a blue circle.
It is method main() that makes a Java class runnable. You cannot run other Java classes that don't contain this method. The compiler will give a NoSuchMethodException.
A different case is with applets, where you don't have to declare main(). Execution starts with method init(), if any, or with paint().
