Investigating Air Flow from a Fan: Vortex, Equations & Airfoils
  • Thread starter Thread starter lucy_b14
    Fan Flow Vortex
This discussion focuses on the airflow characteristics from a fan, specifically the formation of vortex shapes and the potential for airfoils to straighten the flow. It is established that the airflow behind a fan is not inherently vortex-shaped; rather, the design of the blades can eliminate swirl. The use of airfoils or stator blades is recommended to reduce turbulence and noise by redirecting the airflow into a straight path. Key concepts include momentum transfer and shear forces affecting the airflow dynamics.
  • Understanding of vortex dynamics in fluid mechanics
  • Familiarity with turbomachinery principles
  • Knowledge of momentum transfer in airflow
  • Basic concepts of shear forces in fluid flow
  • Research "Turbomachinery blade design for swirl elimination"
  • Study "Momentum transfer in fluid dynamics"
  • Explore "Airfoil design principles for airflow straightening"
  • Investigate "Shear forces in airflow and their effects"
Students in physics, engineers specializing in fluid dynamics, and designers of fan systems seeking to optimize airflow efficiency and reduce turbulence.
lucy_b14
I am doing an investigation into the air flow from a fan in my physics class. I need to know why the reason why air flows in a vortex shape from the fan (in physics terms), and what equations I can investigate (anything, e.g thrust etc).
Also, I believe the airflow from a fan can be straightened using airfoils. Could anyone tell me how this works?
Thanks! :smile:
Do you mean behind or beyond the fan? The flow behind the fan is not necessary vortex shaped. One can lay out a blade design such that the air swirl is eliminated. Upstream the fan, the flow starts to be vortex shaped due to the proper rotation of the blades. But the very small dynamic viscosity of the air makes almost imperceptible that shape.
With the airfoils maybe you are referring to the special design I mentioned above in order to eliminate swirl. The swirl behind a fan enhances noise and turbulence. So that, designers usually employ some special configurations of the blades or add stator blades (airfoils as you named) to deflect into a straight flow the stream. Try to consult some book of Turbomachinery, where you will see the blade schemes for swirl elimination.
The fan blades are rotating and due to friction with the air, they will impart a rotational component to the flow, as well as an axial flow parallel to the axis of rotation. Think of momentum transfer.
Airfoils and ducts can reduce rotational flow, but as the air leaves the fan, the rotational flow will interact with the static air around it and the rotational flow will dissipate. Think of shear forces.
  • · Replies 21 ·
