Calculating Upward Support Force on a Rigid Beam
  • Thread starter Thread starter guru
    Beam Force
The discussion focuses on calculating the upward support force exerted by support 1 on a 3.0-meter-long rigid beam with a mass of 100 kg, supported at both ends. The weight of the student, calculated as 784 N, and the weight of the beam, 980 N, are critical in determining the forces involved. The correct method involves summing the moments around the supports, leading to an upward force of 751.33 N exerted by support 1 after accounting for the weight of both the student and the beam.
  • Understanding of static equilibrium in rigid bodies
  • Knowledge of calculating moments and forces
  • Familiarity with Newton's laws of motion
  • Basic principles of mechanics related to beams
  • Study the principles of static equilibrium in rigid body mechanics
  • Learn about calculating moments and their applications in engineering
  • Explore Newton's laws of motion and their implications in structural analysis
  • Investigate different types of beam supports and their effects on force distribution
This discussion is beneficial for physics students, engineering students, and professionals involved in structural analysis and mechanics, particularly those focusing on static systems and force calculations.
guru
A 3.0-m-long rigid beam with a mass of 100 kg is supported at each end. A
80 kg student stands 2.0 m from support 1. How much upward force does support 1 exert on the beam?
I first found the weight of the student to be 784N.
so 784N*2cm =F*3cm
F= 522.67N
is this right?
No, its not. I think you forgot to take the moment caused by the weight of the beam.
I think this is how it should be done:
(2x784)+(1.5x980) = 3xF
This gives us the value of F(Force on the other support)=1012.67N
Substracting this value from the total downward force(784N+980N) we get the upward force exerted by the support1 be 751.33N
Yes, I forgot to consider the weight of the beam.
Thanks.
  • · Replies 18 ·
  • · Replies 52 ·
12K
9K
