Determining the support reactions of a frame
The discussion revolves around determining the support reactions at points A and B of a frame structure. Participants are addressing the application of static equilibrium equations to solve for unknown forces and moments in a mechanical context.
  • Homework-related
  • One participant presents a moment equation about point A to find support reactions, noting the presence of four unknowns and only three equations.
  • Another participant suggests considering the other part of the frame that includes support B to increase the number of equations available for solving the problem.
  • A later reply proposes that after taking moments for each side, it may be possible to express Cx in terms of Cy or vice versa to simplify the solution process.
  • Another participant emphasizes the importance of correctly applying sign conventions when solving for Cx and Cy, indicating that the direction of forces must be consistent across the sections of the frame.
Participants generally agree on the need to consider additional equations from the other support to solve the problem, but the specific approach to solving for the unknowns remains a point of discussion.
There is an indication of missing assumptions regarding the directions of forces and the specific conditions at the supports, which could affect the solution process.
hobbyenthusia
Here is a link to the problem:
http://img62.imageshack.us/img62/374/frameow.jpg"
I am trying to find the support reactions at A and B.
I separated the frame at the hinge(call it C) into two parts and took the moment equation about point A.
This gave me: [itex]\Sigma[/itex]Ma = -60(25) - 62.5(12.5) + Cx(25) + Cy(25)
The forces in the y:[itex]\Sigma[/itex] Fy = -62.5 + Cy + Ay
The forces in the x: [itex]\Sigma[/itex] Fx =60 + Ax - Cx
From here I am unsure what to do as I have four unknowns and only three equations.
:smile:Hello hobbyenthusia(st), welcome to these forums!:smile:
Try looking at the other part of the frame that includes the support at B. That should give you a total of 6 equations with a total of 6 unknowns.
I completely missed that. Thank you.
After taking the moments for each side is it as simple as solving Cx in terms of Cy or vice versa and finishing it up?
Yes, solve for Cx and Cy and the rest will follow. Please watch plus and minus signs! If Cx is assumed or found to act to the left on the left section, it must act to the right on the right section.
