Calculating Speed in Inelastic Collisions
The discussion revolves around calculating the speed of two colliding trollies in an inelastic collision scenario. The original poster presents a specific problem involving a 3kg trolley and a 2kg trolley, both moving in the same direction, and seeks to determine their combined speed after the collision.
  • Participants discuss the application of conservation of momentum for inelastic collisions, questioning the correct setup of the momentum equation and the interpretation of final velocities. The original poster expresses uncertainty about the variables and calculations involved.
There is an ongoing exchange of ideas regarding the correct formulation of the momentum equation and the interpretation of variables. Some participants provide guidance on how to approach the problem, while others clarify the implications of the masses sticking together after the collision. The discussion reflects a collaborative effort to understand the concepts involved.
The original poster mentions being a year 10 student, indicating a potential level of familiarity with physics concepts, but also expresses uncertainty about the equations and terminology used in the discussion.
grahammm
Hi,
I have the following question to solve, and whilst I've got ideas I have no idea if there right:
In each of the following experiments, showin in the diagram the two trollies collide and stick together. Work out the speed of the trollies after collisions.
i) a 3kg trolley traveling at 3m/s towards a 2kg trolley traveling at 2m/s. The 2kg trolley is heading same direction as 3m's one and is infront.
Do we use F=ma ?
Thanks
Graham
Use the conservation of momentum
m1u1 + m2u2 = m1v1 + m2v2
assign each mass to m1 and m2, u is the initial velocities. this particular example is a completely inelastic collision so there will be only 1 mass (m1 + m2) with a common velocity after the collision. Hope this helps
Thanks for that. One more question what is V1 and v2 final velocity which is presumably 0?
Or do I have to sub in the values and work them out?
Thanks for your help, it's greatly appreciated
Graham
since the masses stick together the second half of that equation i wrote would be (m1 + m2) x common velocity of the two. there is no v1 and v2 because they have stuck together and will both be traveling at the same velocity. the final velocity won't be zero though. after they have stuck together they will move off together with a common velocity. does that help?
With that in mind is the following right:
(m1 X u1) + (m2 X u2) = (m1 X v1) + (m2 X v2)
(3*3) + (2*2) = (3*v1)+(2*v2)
13 = (m1+m3) * v (is that the right letter to use?)
13 = 5 * v
v = 13/5
v = 2.6
Is that right, and if not where do you mind explaining where I went wrong please
Thanks
Graham
(m1 X u1) + (m2 X u2) = (m1 X v1) x (m2 X v2)
13 = 5 * v
v = 13/5
v = 2.6
Thanks
Graham
You've used 2 kg as your mass for one of the trolleys, though above you said it was 24g. You made a typo by putting x on the RHS of your top line, when you meant +, but apart from that it looks ok. Yes, v is the right letter for velocity (were you not taught the usual symbols for things like velocity then?). Also, you don't need to bother putting v1 or v2, just a v in the 2nd line, as you know they're going to move off with the same velocity.
Thats what I got, yes hopefully :)
The letter you use is up to you really, as long as you don't confuse yourself. Make it clear that one side is the initial velocity and the other is the final velocity. i just used v because its what I use for final velocity. In this case I would have noted it as Vc (small c at bottom) simply to remind myself it was a common velocity as the two masses had stuck together and moved off with the same velocity. Does that make it clearer?
Sorry I meant 2kg, a typo there. I also mistyped the x on the RHS top line, they should have been +.
Thanks for all your help, I do not have my exercise book so couldn;t remember the equation for it. In case your wondering I'm an english pupil in year 10 which makes me 15 yrs old, so hopefully this was the right forum to posst in.
Once again thanks for all your help.
I have more questions to do so may be back
Graham
I just knew I'd be back:
A field gun of mass 1000kg, which is free to move, fires a shell of mass 10 kg at a speed of 200 m/s.
(b) What is the momentum if the gun just after firing? - Do we use momentum = mass X velocity, and if so what is the velocity it moving back and if so how is that worked out.
(c) Calculate the recoil velocity of the gun. - Is that an impulse, i.e.g. Ft= mv-mu
Cheers
Graham
The conservation of momentum applies to this one again, m1u1 + m2u2 = m1v1 + m2v2
Initially everything is at rest so the left hand side of that equation will equal 0. (1000*0) + (200*0). Whats the final velocities? Try it from there.
(Others feel free to correct me if I am leading him astray :) )
  • · Replies 20 ·
  • · Replies 16 ·
