Help! Find the Magnitude of a Displacement Vector
The displacement vector problem involves a woman walking 143m at an angle of 55° east of north, followed by 178m directly east. The correct magnitude of the resultant displacement vector is 306m. The calculations for the x and y components of the initial vector (Ax and Ay) were correctly derived using trigonometric functions, but the angle used was incorrect. The angle should be adjusted to 35° to accurately calculate the final displacement vector.
  • Understanding of vector components and trigonometry
  • Familiarity with the Pythagorean theorem
  • Knowledge of angle measurement in navigation (degrees)
  • Ability to perform basic arithmetic operations with vectors
  • Study vector addition and subtraction techniques
  • Learn about trigonometric functions and their applications in physics
  • Explore graphical representation of vectors for better visualization
  • Review problems involving displacement and resultant vectors in physics
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators seeking to clarify concepts related to displacement and vector calculations.
DavidAp
A woman walks 143m in the direction 55° east of north, then 178m directly east. Find the magnitude of the displacement vector.
Answer: 306m
Relevant equations:
I will use vA as a shorthand to represent vector A and ||vA|| to represent the magnitude.
Ax = ||vA||cos(theta)
Ay = ||vA||sin(theta)
||vA|| = sqrt(Ax^2 + Ay^2)
Since I know the magnitude of vA (assuming vA is the starting vector) and the angle in which she left the origin of the coordinate grid I can use the two equations stated above to find the values of Ax and Ay.
Ax = 143m*cos(55) = 82.02m
Ay = 143m*sin(55) = 117.14m
Now I add vA + vB (<82.02m, 117.14m> + <178m, 0m>) to obtain vC, the vector displacement between her starting position to her final position. However, when I go and find the magnitude of the vector I always come out with the wrong answer, 285.19m.
vC = <260.02m, 117.14m>
||vC|| = sqrt(260.02m^2 + 117.14m^2) = sqrt(81332.18m^2) = 285.19m.
What did I do wrong? I thought this would be a simple problem but I keep coming out with the wrong answer. Can someone help me?
The problem is that you're angle is wrong. Try drawing a small graph with the angle starting from the positive y-axis (north) and going towards the x-axis (east). You see that the 55° angle is made with the y-axis, and not the x-axis.
Yes the angle is wrong. Since they say east of north (which I personally think is a stupid way to say) they mean 90-55=35 degrees. The rest is correct.
11K
