New Reply
oscillating system stability
Share Thread
Sep2-11, 08:40 AM   #1
Lets consider this definition: If the average power supplied to the system (absorbed power) is less than the average power lost by the system (emitted power) then the system is stable (during the time in which the power was averaged). Is such a definition of stability valid?
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Sep2-11, 11:40 AM   #2
What kind of system do you have in mind? An exploding gas tank emits more power than it it absorbs, but I would not consider it stable. When you say a system emits more power than absorbs, that word that comes to mind is "active" (as opposed to passive), not "stable". For instance, if you shine a seed laser on a slab of rubber, it is passive and absorbs the energy. This is a passive material. If you shine a seed laser at a properly prepared tank of gas, it will amplify the signal. This is an active material.
Stability is better defined as a centroid of some sort of the system staying constant, such as the combined center of mass of two orbiting masses, or the equilibrium point of an oscillating mass. Stability typically happens in potential wells, whereas unstable equilibrium happens on potential peaks of potential saddle points.
Sep2-11, 12:19 PM   #3
I mean oscillating system which can be e.g. a mass connected to a spring, and the other end of the spring is forced with an oscillating force.
Sep2-11, 12:25 PM   #4
I don't think such a system could be called unstable for any type case, unless the spring breaks. You could get erratic behavior, if the driving force oscillated slightly faster or slower than a natural frequency, but I would still consider it stable.
New Reply
Similar discussions for: oscillating system stability
Thread Forum Replies
Vertically oscillating spring-mass system Introductory Physics Homework 7
Oscillating system (small board on a halfpipe) Classical Physics 7
find max energy stored in oscillating system Introductory Physics Homework 1
Design with Springs in an Oscillating System Mechanical Engineering 0
Energy of an oscillating system Introductory Physics Homework 9
