Question about humidity in milk
  • Thread starter Thread starter chem_tr
    Humidity
The discussion revolves around a friend's inquiry regarding the evaporation of water vapor from hot milk placed in a bowl, focusing on theoretical calculations and models related to humidity and temperature changes over time. The context includes aspects of heat transfer and mass diffusion, as well as potential mathematical approaches to quantify the evaporation process.
  • Homework-related
  • One participant suggests that the problem may relate to Raoult's or Henry's Law, indicating that knowledge of the surrounding humidity could help determine the equilibrium percentage of water in the solution.
  • Another participant questions the assumption that water will be lost from the milk, proposing that the vapor pressure decreases with temperature and asking if the milk equilibrates at 80°C before being placed in the bowl.
  • A participant mentions that the heat dissipated through evaporation can be calculated as the product of the quantity of water evaporated and the heat of vaporization.
  • One participant references a transport phenomena principle, suggesting a formula involving flow rate, driving force, and resistance to flow, which could be relevant to the mass transfer of water vapor.
  • Another participant notes that chemical engineers might be more involved in these calculations, while also acknowledging the potential for physicochemical approaches.
Participants express differing views on the best approach to the problem, with some suggesting equilibrium models and others questioning the assumptions about water loss. There is no consensus on a single method or solution.
The discussion highlights limitations in the assumptions made about the ideality of the situation and the equilibrium process, as well as the potential complexity of the calculations involved.
This discussion may be of interest to those studying heat transfer, mass diffusion, or related fields in engineering and physics, particularly in the context of food processing or thermodynamics.
chem_tr
Hello everybody,
A friend of mine asked me a question regarding one of his milk-processing techniques. He wants to learn if a mathematical formula or a logical approach can be devised.
Okay, the question involves a 1 liter-volume-bowl, whose outer (bigger) radius is 160 mm. He didn't say the inner (lower) radius of the bowl, as I think he considered it not important. He places hot milk at 80°C inside the bowl, and after three hours, he sees that the temperature is lowered to 40°C. He is wondering the amount of water vapor (humidity) evaporated, but in a theoretical basis. I suggested him that he can try simple weighing measures at different intervals, but he insists on seeing a theory-based calculation scheme.
Any suggestions?
Chemistry news on Phys.org
Isn't this a Raoult's (or Henry) Law problem. If you know the percentage water vapor in the surroundings (ie : the dew point of the air in the room, at that particular time), then at any temperature, you can find the equilibrium percentage of water in the solution...can you not?
No, it does not seem like this is the best way to approach the problem. On the other hand, I think it's more likely that water will be added to the milk rather than removed from it. The vapor pressure will decrease with lowering the temperature. Why does he think there will be a loss of water ? And does the milk equilibrate (sit for a long time) at 80C before it is put in the vessel ?
The biggest problem here is that the situation is hardly ideal, nor is it an equilibrium process. Anyways, I need to think about this some more.
Heat dissipated through evaporation is quantity of water evaporated times heat of vaporization.
It's a common homework problem in transport phenomena classes!...unfortunately, I've forgotten too many of the formulas from that class ;) The basic transport principle is: Q = K*(F2-F1)/R, where Q is a flow rate, F2-F1 is a driving force, and R is the resistance to the flow (note this applies to just about anything; mass diffusion, heat flow, even charge--where it's called "Ohm's Law"). K is a proportionality constant that's sometimes needed to harmonize the units. In the case cited, F2-F1 would be the difference in concentration between the atmosphere in the "boundary layer," and at some point beyond, and R would be due to collisions between the molecules of gas. By integrating the expression with respect to time, you get the amount of mass that was transferred in that time...actually, I think there's a much neater formula than the one I gave, but maybe this will help with the general concept.
I think chemical engineers rather than chemists (like me) are more involved with these things. But physicochemical approaches can be devised like russ_waters' one. Please go on giving feedback, and he'll be grateful to you.
13K
  • · Replies 52 ·
9K
