Answer Simple Question: Is it Harder to Turn the Pivot with a Bulb?
  • Context: High School
  • Thread starter Thread starter kishtik
The discussion centers on the relationship between a generator and an electric bulb in a hydroelectric system. When the bulb is connected, it creates a load that resists the generator's rotation, making it harder to turn. Removing the bulb allows the generator to turn more easily, as it then only has to overcome its own friction. Consequently, the energy from the water flowing through the dam is utilized more efficiently when the bulb is off, resulting in increased energy availability.
  • Understanding of basic electrical concepts, including voltage and current.
  • Familiarity with generator mechanics and load characteristics.
  • Knowledge of hydroelectric power generation principles.
  • Awareness of energy conversion and efficiency in electrical systems.
  • Research the principles of electrical load and its impact on generator performance.
  • Explore the mechanics of hydroelectric turbines and their efficiency metrics.
  • Learn about energy conversion processes in electrical systems.
  • Investigate methods to optimize generator performance under varying load conditions.
Electrical engineers, renewable energy enthusiasts, and anyone interested in the mechanics of generators and hydroelectric power systems.
kishtik
I have a questiaon which you can easily answer I think. If you do I'll be :smile: :smile: :smile: because I'm thinking about it for roughly 2 days.
Think we have a generator with an electric bulb connected to it. The PE of the water (from the dam) turns the turbine and our bulb gives light. Now we remove the ampoule and still the turbine is turning but where is the E from the generator going?
In other words is it harder to turn the pivot when a bulb is connected?[?]
Yes, without the bulb the generator turns more easily. The bulb puts a "load" on the generator, making it resist turning. With this load removed, the generator is turning against its own friction, and whatever energy it is making is being used mostly to make the bearings hot and produce those high-pitched soundwaves a generator makes when it spins too freely. But mostly, the energy the bulb is no longer being taken from the moving water. The water flowing through the dam now has more energy because the bulb is off.
Thanks...
  • · Replies 17 ·
