How Many Ways Can You Roll Six Dice with Repeating Numbers?
  • Thread starter Thread starter ArcanaNoir
    Dice Probability
The problem involves determining the number of ways to roll six dice such that there are repeating numbers, specifically focusing on scenarios where at least 2, 3, 4, or 5 numbers are the same. The subject area is probability, particularly combinatorial probability related to dice rolls.
  • Participants discuss the use of negation to simplify the problem, questioning how to calculate the outcomes for different scenarios of repeated numbers. There are attempts to analyze smaller cases, such as rolling 2 or 3 dice, to build understanding. Some participants express confusion regarding the application of formulas and the organization of possibilities.
The discussion is ongoing with various approaches being explored. Some participants have suggested breaking down the problem into smaller components, while others are attempting to clarify the reasoning behind certain steps. There is a mix of understanding and confusion, particularly around the application of probability concepts and the organization of outcomes.
Participants note the challenge of tabulating possibilities and the complexity of deriving formulas for different cases of repeated numbers. There is an acknowledgment of the need for clearer explanations and specific examples to aid understanding.
ArcanaNoir
How many ways can you roll six dice so that at least 2 numbers are the same? At least 3? At least 4? At least 5?
:cry: I've used every equation in the chapter and filled page after page with numbers all moved around. I'm drowning! Please help. I hate probability.
Hi Arcana! :smile:
I'd say this problem is a little too annoying to tackle immediately.
Can you solve first the following for me:
In how many way can you roll 2 dice such that 2 numbers are the same?
Solve this first, then we'll analyze what you did.
Hi ArcanaNoir! :smile:
Let's start with the first.
You need to consider the negation of the outcome to make the problem a lot easier.
What is the negation of: "at least 2 numbers are the same"?
micromass said:
Hi Arcana! :smile:
6/36
because 1,1 or 2,2, etc.
ArcanaNoir said:
6/36
OK, so you're finding tuples with entries between 1 and 6.
So for the first one, you need to find 6 tuples (a,b,c,d,e,f) such that we have at least 2 numbers that are the same.
Following ILS's lead: what is the negation of that.
All numbers are different? Which is nPr(6,6) = 6!
Right? So, okay, for at least 2 are the same it's [tex]6^6-6![/tex] and then over [itex]6^6[/itex] for the probability.
I'm really getting messed up for at least 3 and at least 4.
I'm confused.
ArcanaNoir said:
I'm confused.
Did my tuples analogy confuse you? :frown: I thought it made it easier...
I'll probably leave the thread to ILS, then. He can explain things much better than me :biggrin:
Well yes, the tuples sort of confused me. Can you be more specific and less vague? lol... I need a shove more than a nudge here.
For the next one, first you need to find what the chance is for exactly 2 numbers that are the same.
After that you can find the answer again with negation.
So going back to micromass's example, suppose you have 3 dice. :wink:
How many possibilities for exactly 2 numbers to be the same?
I don't know how to do that without tabling the possibilities.
You might find it easier to start at the other end. How many ways are there to roll 6 dice so all 6 numbers are the same?
To figure out "exactly 5 numbers the same", you have to figure out how many ways you can roll 5 dice so all 5 numbers are the same, the number of ways you can roll the die that's different, and then how they can be arranged, e.g. yxxxxxx, xyxxxx, etc.
Then "at least 5" is "5 all the same" plus "6 all the same".
All right, zooming in.
Suppose we roll the dice one by one.
What is the chance for the first 2 dice to be the same, and the 3rd die to be different?
That might not be a bad idea. If you write out the combinations in an orderly way, you should be able to identify what factors contribute to the total, and then generalize from there.
Exactly 5 is 6 times 5= 30
It's really 3 and 4 that I can't get, and it's because I don't know what formulas to use. The other numbers I did by tabling.
:frown: I don't know.
Does the order matter? I'm assuming it does, in which case you're missing a factor of 6.
Well, the factor of 5 above is the total number of ways to roll one die so that it doesn't match the value of the other dice. In the case where you have 4 matching dice and two different, how many combinations are there for the two dice? You know that each can take on one of five possible values.
There's a formula where you find the number of ways you can arrange the letters in PEPPER,
and you do 6!/(1!2!3!).
So, for exactly 4 numbers the same, would I do 6!/(4!1!1!)?
[edit] never mind I see that's not going to work.
All right.
I'll make the table for you (first 2 dice the same, 3rd different).
Code:
                chance
1 1  2,3,4,5,6  (1/6)(1/6)(5/6)
2 2  any not 2  (1/6)(1/6)(5/6)
3 3  any not 3  (1/6)(1/6)(5/6)
4 4  any not 4  ...
5 5  any not 5
6 6  any not 6
Total chance is: 6 x (1/6)(1/6)(5/6)
I might also say:
First die: any number - chance is 6/6
Second die: the same number - chance 1/6
Third die: any different number - chance 5/6
The product is (6/6)(1/6)(5/6).
Does that make sense?
If so, then what would the chance be for 4 dice with the first 2 dice to be the same and the other 2 different?
crap
halp.
I really want to know how to do this without tabling, but every question people ask, I can only answer by tabling.
I like Serena said:
All right.
do you mean 6 x (6/6)(1/6)(5/6) ?
(6/6)(1/6)(5/6)(4/6)?
To get exactly four dice the same, you need something like XXXX YZ. Let's ignore the order for now. How many values can X, Y, and Z each take?
Similarly, for exactly three dice the same, you need XXX YZW. How many values can X, Y, Z, and W assume?
Do you see a pattern?
x can take 6, y can take 5, and z can take 4.
6, 5, 4, 3
maybe?
is it (6/6)(1/6)(1/6)(5/6)(4/6)(3/6) for exactly 3 numbers the same?
Err... no.
I meant there are 6 (disjunct) lines in the table with each a chance of (1/6)(1/6)(5/6).
So the chance on any of the lines in the table is the sum of the chances.
In this case that is 6 x (1/6)(1/6)(5/6).
Yep! :smile:
And with 6 dies, where the first 2 dices are the same and the rest different?
Next we'll consider the possible rearrangements, like you did with PEPPER.
i like serena said:
and with 6 dies, where the first 2 dices are the same and the rest different?
(6/6)(1/6)(5/6)(5/6)(5/6)(5/6)?
No, Z can take 5 values, right? We don't care if it matches Y.
okay
is it (6/6)(1/6)(1/6)(5/6)(5/6)(5/6) for exactly 3 numbers the same?
To use vela's terminology, we're looking at the pattern XX YZWV here.
so what do we do with it?
No, you allow the 4th die to be the same as the 3rd die here (you didn't before!)
And also for the 5th and 6th die to be the same as one of the other dies.
That's not right.
  • · Replies 16 ·
