A disk 8.0 cm in diameter is initially at rest. A small dot is painted
The discussion focuses on the motion of a disk with a diameter of 8.0 cm that accelerates at 600 rad/s² for 0.5 seconds, followed by a steady angular velocity for another 0.5 seconds. The speed of a dot painted on the edge of the disk at t = 1 s is calculated to be 24 m/s. The calculations utilize the formulas for angular velocity and angular displacement, confirming that the dot completes 300/(2π) revolutions per second, resulting in a total distance of 2400 cm per second. The discussion concludes that the approach of graphing angular acceleration is valid but unnecessary for this problem.
  • Understanding of angular acceleration and velocity
  • Familiarity with the formulas ω = ω₀ + αt and θ = θ₀ + ω₀t + (1/2)αt²
  • Knowledge of the relationship between linear and angular motion (V = rw)
  • Basic graphing skills for visualizing angular acceleration
  • Study the concept of angular motion in detail, focusing on rotational kinematics
  • Learn about the relationship between linear speed and angular speed in circular motion
  • Explore the implications of constant angular acceleration on motion
  • Investigate real-world applications of rotational dynamics in engineering
Students and professionals in physics, mechanical engineering, and anyone interested in understanding rotational motion and dynamics.
guru
A disk 8.0 cm in diameter is initially at rest. A small dot is painted on the edge of the disk. The disk accelerates at [tex]600rad/s^2[/tex] for .5s, then coasts at a steady angular velocity for another .5s.
What is the speed of the dot at t = 1 s?
Through how many revolutions has it turned?
I approached the first question by drawing a graph of the angular acceleration Vs. time. I then obtained the angular velocity by finding the area under the graph.
I then used the formula V=rw to get the speed.
I obtained 24m/s as my final result.
Is this reasonable?
For constant angular acceleration:
[tex]\omega = \omega_0 + \alpha t[/tex]
[tex]\theta = \theta_0 + \omega_0 t + (1/2)\alpha t^2[/tex]
Your graph of the angular acceleration should be a horizontal straight line so the area under it is just the area of a rectangle: the length of the segment on the "t" axis is 0.5 seconds and the height is 600 rad/s2. That's exactly the same as multiplying (0.5 s)(600 rad/s2)= 300 rad/s. "Graphing" works, but seems unecessary to me.
To get the speed of the dot, note that at 300 rad/s it completes 300/(2pi) revolutions per second and each revolution has length 2pi(8) cm: the dot completes 300(8)= 2400 cm per second, exactly what you did.
To get the number of revolutions completed you will need the second formula James R gave for the first 0.5 second, then add 150/2pi revolutions for the second 0.5 second.
  • · Replies 22 ·
14K
12K
  • · Replies 18 ·
22K
