| New Reply |
Stall Speed vs. Weight and Altitude |
Share Thread | Thread Tools |
| Sep5-11, 03:45 PM | #1 |
Can someone explain how and why stall speed (TAS?) varies with aircraft weight and altitude? If you need equations to explain this, I can still handle algebra, but I have forgotten all of my college calculus! Thanks.
| Sep5-11, 09:29 PM | #2 |
If your weight increases, then the amount of lift you must produce increases. But your maximum obtainable CL does not change. So for the same CLmax the heavier aircraft would have to fly faster, so the stall speed would increase.
The stall speed varies with altitude because the density of the air varies with altitude. At a higher altitude the density decreases so again, for the same CLmax you must fly at a faster speed to achieve the same lift at a higher altitude. |
| New Reply |
| Thread Tools | |
Similar Threads for: Stall Speed vs. Weight and Altitude
| Bat Speed vs Bat weight | Classical Physics | 23 | ||
| Determine the Altitude of a Satellite above Earth Given it's Constant Speed | Introductory Physics Homework | 1 | ||
| Pressure Altitude vs. Density Altitude | Aerospace Engineering | 0 | ||
| Altitude for Specific Weight | Introductory Physics Homework | 5 | ||
| Speed/Weight | General Physics | 2 | ||
