Why do we need an m between -m2 and m1 to prove Theorem 1.20?
  • Context: Graduate
  • Thread starter Thread starter Khichdi lover
    Doubt Theorem
The discussion centers around the necessity of finding an integer m that lies between -m2 and m1 in the context of proving Theorem 1.20, specifically regarding the existence of a rational number p between two real numbers x and y. The scope includes mathematical reasoning and conceptual clarification related to the Archimedean property and the construction of bounds.
  • One participant questions why it is necessary to find an m between -m2 and m1, suggesting that it might suffice to establish an upper bound with m1 alone.
  • Another participant explains that the existence of m requires the set of integers less than nx to have a lower bound, which is provided by -m2.
  • A later reply raises a concern about whether 'a' should belong to the set of integers instead of the set of naturals, noting that the set of integers may not have a minimum.
  • Subsequent responses confirm the need for integers and acknowledge the earlier misunderstanding regarding the use of natural numbers.
Participants express varying levels of understanding regarding the necessity of -m2, with some clarifying its role while others remain uncertain about the implications of using natural versus integer sets. The discussion does not reach a consensus on the initial question posed.
The discussion highlights the importance of bounds in mathematical proofs and the implications of using different sets (naturals vs. integers) in defining minimums, which may affect the construction of m.
Khichdi lover
https://www.physicsforums.com/showthread.php?t=253563
There is this post on this theorem. But the issue I wanted to discuss isn't discussed there fully(so far as I could follow the thread). So I am creating this thread for that issue, so as to avoid necro-post in that thread.
Unassuming said:
Pg 9
If x in R, y in R, and x<y, then there exists a p in Q such that x<p<y.
Proof:
Since x<y, we have y-x>0, and the archimedean property furnishes a positive integer n such that
n(y-x)>1.
Apply the archimedean property again, to obtain positive integers m1 and m2 such that m1>nx, m2>-nx. Then
-m2<nx<m1.
Hence there is an integer m ( with -m2<= m <= m1) such that
m-1 <= nx < m
If we combine these inequalities, we obtain
nx<m<= 1 + nx < ny.
Since n>0, it follows that
x < m/n < y. This proves (b) with p = m/n.
My doubt is regarding m. Why do we have to find an m which lies between -m2 and m1.
Why can't we directly say that there exists an m1 which is greater than nx (by Archimedian property).
And then go on to say that there would be an m less than or equal to m1 which is such that nx lies between m-1 and m.Why do we have to show that -m2 is less than nx. Do we have to establish that nx lies in an interval which has both a lower and upper bound(-m2 and m1 respectively). Can't we simply establish that nx lies in an interval which has an upper bound ( i.e m1) and then go on to show existence of m ? Why do we need m2
*I am sorry if I am assuming anything which is not obvious and hence needed to be proven. I am new to analysis , hence I am not too sure of what is obvious and what is not. *
Unassuming said:
He might have needed the m1 and m2 because we cannot just pick any number. We therefore used archimedian property to find m1 and m2, and then again to find a m in between them but a little to the "right" of nx.
is the above , the correct reason ? Still I am having difficulty understanding the need for -m2.
The thing is that we have to construct m such that
[tex]m-1\leq nx<m[/tex]
For this, we choose
[tex]m=\min\{a\in \mathbb{N}~\vert~nx<a\}[/tex]
But in order for that minimum to exist, we need the set [itex]\{a\in \mathbb{N}~\vert~nx<a\}[/itex] to have a lower bound. This is exactly what [itex]-m_2[/itex] provides...
ok got it . Thanks.
But 1 doubt still remains though .
in this set you pointed out -
shouldn't 'a' belong to the set of integers instead of the set of naturals.
As any set of naturals will have a minimum. But any set of integers may not have a minimum.
Khichdi lover said:
ok got it . Thanks.
in this set you pointed out - [tex]{a\in \mathbb{N}~\vert~nx<a\}[/tex] ,
Yes, of course. It needs to be the integers :blushing:
Thanks. Sorry didn't get the latex code correct.:cry:
DOUBT resolved!
  • · Replies 17 ·
