Current Electricity - current flowing through hand
The discussion revolves around a problem in current electricity, specifically focusing on calculating the resistance of human skin and estimating the current flowing through a person who accidentally contacts a live wire. The problem involves resistivity values and geometric considerations of contact area.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of resistance based on skin thickness and area, with one participant successfully solving the first part of the problem. Questions arise regarding the effect of contact area on resistance and the implications of potential difference along the wire.
Some participants have provided guidance on the relationship between contact area and resistance, while others are exploring the implications of potential difference along the wire. There is an ongoing exchange of ideas, with no explicit consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information available for discussion. The original poster expresses difficulty in solving the second part of the problem, indicating a need for further clarification on the concepts involved.
sharkey1314
Current Electricity -- current flowing through hand
i)For a layer dry skin 1mm thick, determine the resistance of a 1 cm^2 area of skin.
Resistivity of dry skin : 3 x 10^4 ohms m
[3.0 x 10^5 ohms ]
ii)A person, who is well-earthed, accidentally grabs a wire of diameter 0.4 cm at a potential of 50V. His hand makes contact with the whole circumference of the wire over a distance of 9cm.
The average thickness of skin of his hand is 1mm. Estimate the current flowing through him.
[1.89 mA ]
Resistance = resistivity(length)/area
V = IR
For i) , I managed to solve it.
Using the equation directly.
For ii), I couldn't get the answer.
First, I calculate the surface area of the cylinder ( wire ) where it is in contact with the wire.
Surface area = pi . diameter . length
= pi . (0.4 x 10^-2) . (9 x 10^-2)
= 0.0011309 m^2
Then I multiply this surface area with the resistance of dry hand obtain in i)
Total resistance = surface area x resistance of dry skin 1 mm thick, area of 1m^2
= 0.0011309 x 3.0 x 10^5
Next, I used V = IR. Sub in total resistance and P.D of 50 V
The answer I got was 0.147 A. Totally off.
Thanks for the time !
hi sharkey1314! :smile:
but won't the resistance go down if the area of contact increases? :wink:
Thanks a lot. I re-used the equation for resistance to find the new resistance of the hand. Then, after using V = IR, I managed to get the answer =D
Just to clarify, what does a potential of 50V means ? And does the potential changes along the length of the wire. i.e. the start and end point will have different potential ? If so, does the answer change since potential varies.
it means the potential difference between the wire and the ground …
ie from your hand to your foot! :biggrin:
Yes, but only very slightly …
the drop in potential along a wire is IR, and R for a wire is usually very small! :smile:
  • · Replies 42 ·
