| New Reply |
Calculating magnetic flux |
Share Thread | Thread Tools |
| Sep7-11, 05:03 AM | #1 |
A cube of edge length 0.05m is positioned as shown in the figure below. A uniform magnetic field given by B = (5 i + 3 j + 2 k) T exists throughout the region. ![]() a) Calculate the flux through the shaded face. 2. Relevant equations [itex]\phi[/itex] = B.A cos [itex]\theta[/itex] 3. The attempt at a solution The area would simply be 0.0025m^2 I'm having trouble understanding how to get the angle and also how to interpret the given magnitude of the magnetic field, it's a vector quantity. I thought at first the way to get the angle was to assume that the surface of the cube could be considered a vector as well, that way it would only have the j component since it's only got a direction in the y-axis. Then using the formula for the angle between two vectors, I got 53.5 degrees, though I'm not too sure how to use the given magnetic field value. |
| Sep7-11, 06:48 AM | #2 |
Hi NewtonianAlch!
![]() just do the inner product! (dot product)the area can be represented by a vector of magnitude A in the normal direction, so just "dot" that with the field, and that's your flux! ![]() (or you can "dot" it with the unit normal, and then multiply by the area … same thing) |
| Sep7-11, 07:47 AM | #3 |
Hi tinytim,
Do you mean to say: (5, 3, 2)[itex]^{T}[/itex].0.0025 which is (5*0.0025 + 3*0.0025 + 2*0.0025) B.A |
| Sep7-11, 09:01 AM | #4 |
No, (5,3,2).(the unit normal times 0.0025)
![]() (btw, you can't write BT.A … it's either BTA or B.A )
| New Reply |
| Thread Tools | |
Similar Threads for: Calculating magnetic flux
| Measuring Magnetic Field Intensity (H) and Magnetic Flux Density (B). | General Physics | 10 | ||
| magnetic flux density vs magnetic flux | Classical Physics | 5 | ||
| Magnetic fieldstrength, magnetic flux, magnetic flux density | General Physics | 0 | ||
| Tough tough question: Calculating magnetic Flux in water | Classical Physics | 0 | ||
| Magnetic Flux & Electric Flux | Classical Physics | 2 | ||
