What is the displacement of the particle
The displacement of a particle with a velocity function defined as v = (5.5 m/s4)t3 - (5.4 m/s) can be calculated by integrating the velocity function over the interval from t = 3.5s to t = 9.0s. The correct approach involves finding the anti-derivative of the velocity function, resulting in the position function x = (5.5/4)t4 - 5.4t + x0. Evaluating this position function at the specified limits and subtracting the results provides the displacement, while ensuring that the constant x0 cancels out. The rapid increase in speed due to the t3 term explains the initially perceived large displacement value.
  • Understanding of calculus, specifically integration and differentiation
  • Familiarity with the concepts of velocity and displacement
  • Knowledge of anti-derivatives and limits of integration
  • Basic understanding of polynomial functions
  • Study the process of finding anti-derivatives in calculus
  • Learn about the Fundamental Theorem of Calculus
  • Explore polynomial functions and their properties
  • Practice problems involving integration of velocity functions to find displacement
Students and professionals in physics and engineering, particularly those studying kinematics and calculus, will benefit from this discussion on calculating displacement from a velocity function.
ffrpg
Here's my problem, The velocity of a particle is given by
v = (5.5 m/s^4)t^3 - (5.4 m/s), what is the displacement of the particle during the interval t=3.5s to t=9.0s? I don't even know if I started it off right. I recalled seeing something similar to this in calc, so I tried integrating the formula given using 3.5 as 'a' and 9.0 as 'b'. I ended up getting 80440.5 as my answer, but it seems a bit large. I just need to know how to approach the problem. Thanks
"a" and "b"? I don't understand what those are! Oh, you mean the limits of integration. That's exactly what you should do.
What you need to know is that velocity is the derivative of position so position is the anti-derivative of velocity- that is, the integral.
Since v= dx/dt= (5.5)t^3 - 5.4, x= (5.5/4)t^4- 5.4t+ x0. (x0 is the "unknown constant" and would be the position of the particle at t=0). Evaluate at t= 9.0s and t= 3.9s and subtract. (The x0 in each term will, of course, cancel).
Why does your answer seem "a bit large"? With the t^3 term the speed is going to increase rapidly!
Hey thanks for the help. I figured out what I did wrong. I integrated incorrrectly. THANKS!
  • · Replies 23 ·
