New Reply
What would happen if two Earth size planets very slowly collided?
Share Thread Thread Tools
Sep9-11, 08:46 PM   #1
Hypothetically this pseudo-Earth suddenly appears and follows the same orbit as Earth, but moves slightly faster. If it eventually collides with Earth at snail pace what would the gravitational effects be like? (maybe ignore the moons)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep9-11, 10:30 PM   #2
You mean like earth #2 chasing earth #1? well, it would be one hell of an unforgettable sight for a few weeks as the planet approaches. I assume E1 would slow down in it's orbit around the sun as E2 gains speed towards us. Can you imagine the sight as it passes the moons orbit? Scary but fascinating. I picture the planets from the movie Pitch Black, except we all die a feiry explosive death from a planet collision.
Sep10-11, 11:17 PM   #3
Recognitions:
Gold Membership Gold Member
I believe the two planets would pull each other towards themselves and eventually both would be falling towards each other at 9.8 m/s^2 right before they hit.
Sep10-11, 11:29 PM   #4
Community 2012
Recognitions:
Quote by Drakkith View Post
That approximation fails magnificently when you start talking about entire earth-sized objects on a collision course :)
Sep11-11, 12:19 AM   #5
Mentor
Quote by Pengwuino View Post
Well, since g = GMearth/Rearth, and the distance between the centres of the two planets would be 2Rearth right before they hit each other, one would think that the acceleration at that instant would be g/2, no?
This is assuming that the planets have not only the same mass, but also the same size.
EDIT: Nevermind. At this point they really can't be considered to act as point masses and you have to take into account tidal effects and all that...
Sep11-11, 12:48 AM   #6
I had this big chart with a bunch of the stats of gravitational acceleration for both planets at certain distances and velocity changes and all that jazz took a while to do on my computer calculator. But alas I had most of it on an Excel chart and blam crashola program not responding, I was on a roll and hadn't saved in a while... My initial obsessive motivation has mostly drained out of me for now. Might pick it up again tomorrow.
I did make a few mental notes though. Two big factors came in to play: initial distance between Earth 1 and Earth 2, and time until impact. You have any idea what you want those to look like? Either one would do nicely I assume this is for a story. If not and it's just for your own curiosity I'll just throw something together saying they started like 630,729,000m apart moving at the same speed.
I think at point of impact it would be more like an acceleration of 39.2266 m/s2 because Earth 2 is accelerating at 19.6133 m/s2 due to its pull on Earth 1 (9.80665 m/s2) plus Earth 1's pull on it (9.80665 m/s2) and at the same time Earth 1 is decelerating at 19.6133 m/s2 due to the same factors. I could be wrong though.
But regardless the acceleration at point of impact isn't really what matters because you take into account the acceleration due to gravity across the vast distances of space between them and it continually builds up decelerating Earth 1 and accelerating Earth 2 until the impact and at that point it doesn't really matter how snail pace faster Earth 2 was moving or even if Earth 2 was moving slower initially. By the time they collide the impact due to their velocity differential would be quite something. This all of course depends on the initial distance between them.
I was mostly using the equation gh=go(re/(re+h))2 and the variations I derived from it would that equation be correct? Or would I have to double re because there are two Earths?
gh= Earth's gravitational acceleration on a object at a distance outside Earth's radius m/s2
go= Earth's standard gravitational acceleration of an object in m/s2 (usually 9.80665m/s2 but I used both 19.6133m/s2 and 39.2266m/s2 to get results due to 2 Earths being present)
re= Radius of Earth in meters
h= Distance in meters of object outside of Earth's radius
Oh and all my work is disregarding the whole orbital part I haven't really studied orbital acceleration and orbital factors very extensively yet. Also disregarding spin and the influence of the moons. That's just a bit much for me right now.
Sep11-11, 12:54 AM   #7
Community 2012
Recognitions:
Quote by cepheid View Post
Yup it gets a bit crazy :D
Sep11-11, 07:25 AM   #8
Recognitions:
Yep. I don't know the math to say anything else more correct though.
Sep11-11, 12:03 PM   #9
Recognitions:
Retired Staff Staff Emeritus
Quote by blarznik View Post
If you want it to hit the Earth, you don't want it appearing in the same orbit as the Earth.
Here's why. As it begins to approach the Earth from behind, the Earth's gravity starts to pull forward on it. But a forward force acting on a orbiting object pushes it into a higher orbit. higher orbits are slower orbits.
Meanwhile, the planet is pulling backward on the Earth, causing it to fall into a lower faster orbit
So what happens is that before the planet reaches the Earth it will be pushed into an orbit that is higher and slower and the Earth drifts into a lower faster one and will begin to pull away from the planet.
Fast forward up to the point where the faster Earth is catching up to the slower planet. Now the Earth pulls back on the planet and the Planet pulls forward on the Earth. The Earth drifts into the slower orbit and the planet into the faster one. The planet pulls away until it begins to catch up with the Earth again and we are back where we started.
This is called a "horseshoe" orbit, from the the fact that the path of one planet looks like a horseshoe from the perspective of the other.
Sep11-11, 12:18 PM   #10
Recognitions:
Can you elaborate on this a bit? If one object is slowed down and pulled into a "faster" orbit, does that object take a full revolution to get to the required speed for that orbit? And why wouldn't an object that is sped up in it's orbit be lost? How does it slow down to get into the slower orbit?
Sep11-11, 02:43 PM   #11
Mentor
I imagine not. As soon as it descends "deeper" into the sun's gravitational potential well, the potential energy it loses is turned into kinetic energy gained.
Same reason as above, only opposite. It expends energy climbing higher out of the sun's potential well.
Sep11-11, 02:55 PM   #12
Recognitions:
How appropriate that Janus was the first to spot the horseshoe configuration! The best example of this in our solar system are Saturn's moons, Janus and Epimetheus. Here's a webpage I made describing their orbits: http://www.orbitsimulator.com/gravit...les/janus.html
Sep11-11, 06:56 PM   #13
Recognitions:
So if it lost 100 m/s and fell towards the sun, then it gained that 100 m/s plus extra back? That makes sense. As does the opposite effect. Thanks!
Sep13-11, 01:28 AM   #14
What happens when Earth1 and Earth2 pass within each others' Roche limits?
Sep13-11, 08:40 AM   #15
Recognitions:
I don't know this stuff well so sure could be wrong, but my understanding is that the Roche limit has to do with loosely bound objects such as comets and would not apply to strongly bound objects such as a planet.
Sep13-11, 09:08 AM   #16
Quote by phinds View Post
There would still be huge tidal stresses, massive earthquakes, and anything not nailed down (like oceans, atmosphere, people, soil...) would shift in a big way.
It reminds me of science-fiction stories (Rocheworld, heh) by Dr. Robert L. Forward of two planets which were so close that ocean and atmosphere would occasionally spill back and forth.
Sep13-11, 11:07 AM   #17
Recognitions:
It would apply to any object that was massive enough that its own gravity determined its shape. (essentially any body that has pulled itself into a sphere).
New Reply
Thread Tools
Similar Threads for: What would happen if two Earth size planets very slowly collided?
Thread Forum Replies
Calculating the size of planets from length of days. General Astronomy 4
What would happen if two black holes collided? General Astronomy 2
Why Can't Rocky Planets Exceed 14 Times Earth's Size? Astrophysics 25
What would happen if...? (imaginary earth) Classical Physics 4
What would happen if two black holes collided? Astrophysics 2
