Faster than light and time travel
The discussion centers around the implications of faster-than-light (FTL) travel and its potential relationship with time travel and causality. Participants explore theoretical concepts, interpretations of relativity, and the nature of quantum entanglement in the context of these phenomena.
  • Some participants propose that FTL travel could imply backward time travel, potentially violating causality.
  • Others reference the tachyonic antitelephone as a theoretical construct related to FTL communication and time travel.
  • A participant suggests that the Lorentz time contraction formula implies that if FTL were possible, time could become imaginary, reinforcing the idea that FTL travel is problematic.
  • There is a discussion about the relativity of simultaneity, where FTL travel could lead to scenarios where one arrives before they depart, which some argue is a causality violation.
  • Questions arise about whether quantum entanglement, which appears to operate faster than light, could be considered a form of FTL communication and its implications for causality.
  • Some participants express uncertainty about whether group velocity exceeding the speed of light necessarily implies backward time travel.
  • Concerns are raised regarding the nature of length contraction and its implications for physical existence when approaching or exceeding the speed of light.
  • There are inquiries about whether anything can travel backward in time without violating causality, with some arguing that such movement inherently leads to causality violations.
  • A participant discusses the potential for quantum entanglement to be used for communication, while noting the challenges of maintaining entanglement over distances.
Participants express a range of views, with no clear consensus on the implications of FTL travel and its relationship to time travel and causality. Multiple competing interpretations and models are presented, indicating ongoing debate and uncertainty.
Limitations include the dependence on theoretical constructs and interpretations of relativity and quantum mechanics, as well as unresolved questions about the nature of causality in relation to FTL phenomena.
byron178
Why does faster than light travel or propagation mean time travel backwards to violate causality?
DrGreg said:
I see,so if i were in a spaceship and were to faster than light,i would travel backwards in time to the past?
That is one possible interpretation of the Lorenz time contraction formula where, if it were possible for v to be larger than c, then t becomes an imaginary number. A more reasonable interpretation would be that this is yet another reason why one can't go faster than c.
Because of the relativity of simultaneity. If you are traveling faster than light then there are frames of reference where you arrive before you start and that's a violation of causality.
is there anything is physics that travels simultaneity?
how come entanglement happens faster than light?
Because nothing travels and no information is transmitted.
What do you mean by "travels simultaneity?"
Quantum entanglement means, basically:
If 1=A, 2=B.
If 1=B, 2=A.
But what happens is that, when 1 is made to equal A, then 2 equals B.
Or does changing the value of A result in decoherence? I think so, I would just like a confirmation.
what i meant is are there things or situation in physics that travel simultainisly?
ok let me make something clear sorry i didnt,Faster than light travel has to cope with time travel because in one frame it will be seen that the traveler traveled backwards in time,does entanglement deal with faster than light time travel backwards,meanung will some one see entanglement happen backwards in time?
I've read that if group velocity exceeds speed of light, t2- t1 to some reference frame would be reversed to t1- t2, which means to some reference frame there is violation of causality. According to the principle of relativity, no frame is preferred. Therefore this argument is valid. But I forgot how to derive that...
what about lijun wang's expierament done in 2000,does that deal with time travel?
If I was the one about to go faster than c, I would be less concerned about time and causality, much more concerned about length contraction...
Length to "0", then
Through "0" into what?
Negative length?
Imaginary length?
Hyper-real length?
Or length expansion beyond c...
Even if within my frame I measured nothing unusual, how much of "me" continues to function after that transition through true zero length?
Maybe this suggests why nothing should pass through c from either the slower or faster side?
also i forgot to add,can something travel backwards in time and not violate causality?
cause cannot preceed event so to answer your question the answer is no any backward movement in time can only violate causality
Well, you should look at the definition of causality.
"Causality is the relationship between an event (the cause) and a second event (the effect), where the second event is understood as a consequence of the first."
based on this, if you travel backward, what would happen is that you have traveled back before you start travelling. So I think this is the violation
I know that group velocity can exceed the speed of light,but does it travel backwards in time since it travels faster than light?
ok,i was doing some research and it seems that the group velocity can exceed the speed of light and travel backwards in time it just can't send information,is this correct? can something travel faster than light without it traveling backwards in time in any frame?
Thus far nothing has been shown to break the laws of causality as the arguments have always been the no information travels faster than c, with the experiments that have shown that light can appear to travel faster than c giving effect before cause. I've tried numerous times to get a clear cut answer to exactly what they term as no information so I also am curious concerning the answer to your post. The way I've been thinking of FTL effects is similar to GR's observer descriptions. Say in the the case of no time ina Blackhole. To the observer it appears that there is no time, but to matter and energy at that point time behaves normally. This is how I think they mean by backwards in time. That to the observer its effects happen prior to cause, but to the lightbeam its still moving normally. I'm fairly certain that's not quite correct and that there is more to it.
I would be interested in a better understanding of the backward in time description used by Physicists in that regard.. Also recongnizing that due to causality many top notch physicists feel that time travel to a time prior to cause is impossible.
Would it be possible to use quantum entanglement to communicate at any usable distance?
In a similar manner to how two computers talk to each other then yes, Provided they can get the entanglement stable enough to be practical. It could be a usable wireless communication without the use of light or radio. There was a recent article concerning a diode that they fashioned that can generate several million entangled particles per second. I can't recall the exact amount, However certain types of radiation tends to break the entanglement down rapidly, Again its been a few months since I read that article so cannot name the particulars on it. To the best of my knowledge the maximum distance I've heard they achieved is 100 km.
People might want to use up-down spins to correspond to 1s and 0s on one end, and because the opposites will occur on the other, for 1s and 0s to be reversed so as to decode the original message. However, I'm pretty sure that once you try to measure the state of the atom, proton, whatever, it gets manipulated, so whatever you happen to send through quantum entanglement will be corrupted and nothing usable can be actually read.
No, the problem is, that what you read about the state of the entanglement at the receiving end does not tell you anything - unless and until you communicate with the source - which you can only do at luminal or subluminal speeds.
Okay, let me take this hypothetical scenario. Interstellar travelers from Earth are going to Alpha Centauri, and with them they take a quantum-entanglement Internet link to Earth, so they can communicate in a reasonable amount of time (assume they have no FTL technology, that is way too speculative for this era and forum).
For our purposes, let's assume that information is sent from Earth to Alpha Centauri with a binary system, which at Alpha Centauri is "flipped over" so to speak in order to cancel out the flipping which happens with quantum entanglement. So 0s on Earth are converted to 1s in entanglement which are converted to their true form of 0 by the computer. The computer was programmed to do the conversions.
So does this mean that the programmer who wrote the program to "make sense of "the entanglement results, and the fact that the skills to use a computer to "make sense of" the data were taught to the crew, was the necessary subluminal communication component? How does it work, I don't really have a physics background so I don't understand it too well.
All you can do with entangled particles is read what state they are in. As soon as you try to write a new state, the particles are no longer entangled.
If the spacetime continuum is an unviolated principle of nature, then faster than light travel requires backwards time travel. A violation of SR would be a violation of the one or more assumptions about spacetime, as presently defined. If the neutrinos are verified to travel faster (in a local frame) than light speed observed in a vacuum (in a local frame), then given that the scientists at CERN have measured a positive velocity in their experiments, then discovery of FTL travel would be directly incompatible with the existence of a space-time continuum, as presently defined.
It requires backwards time travel in some frames of reference but not in all frames of reference.
That the scientists at CERN have measured a positive velocity in their own rest frame wouldn't mean that the velocity is positive in every frame of reference.
What do you call a velocity that is "positive" when going from point A to point B and "negative" when going from point B to point A? (Hint: It is not velocity as measured by an observer relative to that observer.)
And the focus here anyway is the velocity of neutrinos measured from the laboratory frame in which point A and point B are fixed coordinates. This is what actually matters. The scientists at CERN didn't discover that the neutrinos traveled at 60 m/s now did they?
And how exactly does one travel such that otherwise backward time travel is not observed as backwards? Wouldn't such a traveler be traveling backwards in time too?
  • · Replies 19 ·
  • · Replies 19 ·
