Field Energy and Time Dilation in Relativistic Motion
The discussion revolves around the relationship between field energy and time dilation in the context of relativistic motion. Participants explore whether the increased field energy experienced by a fast-moving object contributes to the phenomenon of time dilation, examining both theoretical implications and the nature of reference frames.
  • One participant suggests that a relativistically moving body encounters more field energy than a slow-moving body, questioning if this energy relates to time dilation.
  • Another participant introduces the idea of "cutting absolute background field lines," questioning the nature of the field being discussed and its measurability across different inertial reference frames.
  • A different participant asserts that time dilation is a reciprocal process, indicating that both fast and slow-moving bodies perceive time dilation in each other without experiencing it themselves, regardless of field energy considerations.
  • One participant agrees with the notion that time dilation and length contraction are primarily functions of relative velocity rather than energy, providing an alternative perspective on the initial claim.
Participants express differing views on the relationship between field energy and time dilation, with no consensus reached on the matter. Some argue for a connection, while others maintain that time dilation is independent of energy considerations.
The discussion includes assumptions about the nature of fields and reference frames, as well as the implications of relativistic effects, which remain unresolved. The definitions of "field energy" and its relevance to time dilation are not clearly established.
keepit
a relativistically moving body passes through much more field energy than a slow moving body per unit time. Does all that field energy have anything to do with the slowing of time in the fast moving object?
Cutting absolute background field lines...?
That begins to sound like an aether field which should not be measurable in any inertial reference frame.
Or what kind of field are you thinking?
Maybe a relativistically moving inertial reference frame would "see" any field lines in such a way as to appear locally "correct" and without conflict from other reference frames' views?
No. Time dilation is a reciprocal process. Your relativisically moving body sees time dilation in the slow moving body just like the slow moving body sees it in the fast moving body. Neither body notices any slowing of time for themself. This is true no matter what field energy or lack thereof is present.
ghwell...good way to explain it...!
I would have said "no, time dilation and length contraction are a function of relative velocity not energy".
  • · Replies 51 ·
  • · Replies 25 ·
  • · Replies 20 ·
