Calculating Rotational Motion: Solving for Time in Uniform Door Rotation
  • Thread starter Thread starter pinky2468
    Axis Rotation
The problem involves calculating the time it takes for two identical doors to rotate through the same angle under the influence of a force applied at their edges. The context is rotational motion, specifically focusing on the differences in torque and angular acceleration for each door due to their differing axes of rotation.
  • Participants discuss the application of torque and moment of inertia to find angular acceleration for each door. There are attempts to relate the equations of motion for both doors, questioning how to incorporate time into their calculations.
The discussion is ongoing with participants exploring different approaches to relate the rotational dynamics of the two doors. Some guidance has been offered regarding the use of torque and angular acceleration, but there is no clear consensus on how to proceed with the calculations.
Participants express uncertainty about the differences in torque due to the application point of the force and the implications for their calculations. The problem is framed within the constraints of a homework assignment, which adds pressure to find a solution.
pinky2468
I am having a very hard time with this problem! Even my teacher had trouble with it(of course we are still expected to have it done on our homework!)
2 doors are uniform and identical. Door A rotates about an axis to its left edge and door B rotates about an axis through the center. The same force F is applied perpendicular to each door at its right edge and the force remains perpendicular to as the door turns. Starting from rest, door A rotates through a certain angle in 3.00s. How long does it take door B to rotate through the same angle.
So I got as far as 1/3ML^2(alpha)=1/12M(L/2)^2(alpha) and then I get stuck on how o make time fit in. I have been looking at all the equations for rotational motion, but I don't know which one?
Use [itex]\tau = I \alpha[/itex] to find the [itex]\alpha[/itex] for each case. Then apply the kinematic equation that gives [itex]\theta[/itex] as a function of time.
This is what I am coming up with:
1/3ML^2(2[itex]\theta[/itex]/t^2)= 1/12ML/2^2(2[itex]\theta[/itex]/t^2)
ML^2 cancel out and so does the 2[itex]\theta[/itex]
and I am left with (1/3)(1/t^2)=(1/12)(1/4)(1/t^2)
Is that right? Where do I go from there?
The torque is different in each case.
But the same force is applied to each door in the same spot?? If the torque is different then I am not sure what to do b/c the only known value is time.
A: torque is FL
B: torque is FL/2
That is what I had, but can't I set them equal to each other?
No, since they are not equal! You can easily relate them though.
You should use the information given to find out the angle for door A. Treat door A and B as separate cases, door A is there just to tell you the angle. Then you find out the [tex]\alpha[/tex] from the [tex]\tau and I[/tex] that you already have. If you can find out the angle of door A, then you shouldn't have problem working out time for door B because it's sort of working backward with the method you used for A.
13K
  • · Replies 88 ·
24K
