Mastering Statistics: Calculating Fill Volumes and Probability Distributions
  • Thread starter Thread starter forty-twwo
    Statistics
This discussion focuses on calculating fill volumes and probability distributions related to intravenous fluid bags filled by an automated machine. The standard deviation of the average fill volume for 20 bags is determined using the formula 0.08 / √20, resulting in a standard deviation of 0.01789 fluid ounces. The probability of the average fill volume being below 5.95 fluid ounces is calculated using the z-score formula, while the mean fill volume required for a probability of 0.001 below 6 ounces is also derived. Additionally, the discussion addresses the cumulative distribution function and statistical properties of a continuous random variable defined by a specific probability density function.
  • Understanding of normal distribution and standard deviation
  • Familiarity with z-scores and probability calculations
  • Knowledge of cumulative distribution functions (CDF)
  • Basic statistics concepts, including mean, median, and variance
  • Learn how to derive cumulative distribution functions from probability density functions
  • Study the Central Limit Theorem and its implications for sample means
  • Explore advanced probability concepts, such as moment-generating functions
  • Practice calculating probabilities using different statistical software tools like R or Python
Statisticians, data analysts, and anyone involved in quality control processes for manufacturing, particularly in the medical or pharmaceutical fields.
forty-twwo
To be honest I have no real idea how to do this. I know of the probability density function, and the cumulative probability function, but using them is another difficulty I'm trying to overcome.
My questions are,
Intravenous fluid bags are filled by an automated filling machine. Assume that the
fill volumes of the bags are independent, normal random variables with a standard
deviation of 0.08 fluid ounces.
(a) What is the standard deviation of the average fill volume of 20 bags?
(b) If the mean fill volume of the machine is 6.16 fluid ounces, what is the
probability that the average fill volume of 20 bags is below 5.95 °uid ounces?
(c) What should the mean fill volume equal in order that the probability that the
average fill volume of 20 bags is below 6 ounces is 0.001?
Second question is,
A continuous random variable X has the probability density function f(x) given
below.
0 x < or equal to 0
f(x) = 4x3 0 < x < or equal to 1
0 x > 1
(a) What is the cumulative distribution function of the random variable X?
(b) What are the mean and median of the random variable X?
(c) What is the variance of the random variable X?
(d) What is the probability that the random variable takes a value greater than
its mean?
Any help or tips so I can figure these out would be greatly appreciated. Thanks,
Well, what formulas and equations do you know? In particular, what is the standard deviation of an average of n trials from a normal distribution?
What have you tried on these?
I believe I just solved all of the first question. For Part A I used the equation of the standard deviation divided by the square root of the number or trials, so 0.08 / sqrt of 20.
Then for Part B I used the z score formula of (X-μ)/σ, then used a z-table I found online. For Part C I did a similar thing but basically used the equation and table in reverse.
Question 2 is still a bit of a mystery for now though,
9K
