Physics projectile problem - finding vertical range using the horizontal range
The discussion focuses on calculating the maximum vertical height a baseball player can achieve when throwing a ball with a horizontal range of 54 meters. The relevant physics equations include d = Vo*t + 0.5*a*t^2, where vertical acceleration (a) is 9.8 m/s² and initial vertical velocity (Vyo) is 0 m/s. The user attempts to graph a parabola to find the vertical height but encounters confusion due to insufficient information about the initial velocity or angle of projection. The key takeaway is that the optimal angle for maximum range is 45 degrees, which should be considered for accurate calculations.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Basic graphing skills for parabolic functions
  • Knowledge of maximum range conditions in projectile motion
  • Study the derivation of projectile motion equations
  • Learn how to calculate maximum height using initial velocity and angle
  • Explore the effects of air resistance on projectile trajectories
  • Practice solving various projectile motion problems with different initial conditions
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the mechanics of throwing objects in sports.
gchuchro
What is the maximum vertical height to which a baseball player can throw a ball if his maximum throwing range is 54 m?
vertical: a=9.8 m/s/s, Vyo=0 m/s, d=?, t=?
horizontal: d=54 m, a=0 m/s/s, Vxo=?, t=?
d=Vo*t+.5*a*t^2
Since Vo or theta was not given, I decided to graph a parabola who's derivative would be 9.8t...so on my calculator I graphed 4.9t^2. Since I know it traveled 54 meters horizontally, I thought the y value of the parabola when x=27 would be my answer..but it clearly was not.
Any ideas on how to approach this? I'm confused because of the few givens I have to work with.
Hi gchuchro and welcome to PF!
Firstly a question from me: how would you throw a ball if you wanted to throw it furthest away?
28K
