Find Moment of Inertia of Figure w/ M, L, m_1 & m_2
The moment of inertia for the given figure can be calculated using the formula I = (1/12)ML^2 + (m_1)(1/2L)^2 + (m_2)(1/4L)^2, where M is the mass of the rod, L is its length, and m_1 and m_2 are the point masses located at specified distances. The parallel axis theorem is unnecessary in this scenario as the masses can be treated as point masses. The correct approach involves summing the moment of inertia of the rod with the contributions from the point masses.
  • Understanding of moment of inertia concepts
  • Familiarity with the parallel axis theorem
  • Knowledge of point mass inertia calculations
  • Basic principles of rotational dynamics
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the application of the parallel axis theorem in different contexts
  • Explore the concept of point masses in rotational motion
  • Review examples of composite bodies and their moment of inertia calculations
Students and professionals in physics and engineering, particularly those focused on mechanics and dynamics, will benefit from this discussion on calculating moment of inertia.
quick
i need to find the moment of inertia of this figure
http://s93755476.onlinehome.us/stuff/knight.Figure.13.54.jpg
and express my answer in terms of M, L, m_1, and m_2.
i tried using the parallel axis theorem using (1/12)ML^2 since it is a thin rod with the axis of rotation about the center but I am not sure what to use for Md^2. in I = I_cm + Md^2.
i was thinking maybe I = (1/12)ML^2 + (m_1)(1/2L)^2 + (m_2)(1/4L)^2. but it didn't work.
any help is appreciated.
I believe you are on the right track. Use the regular formula to find the moment of inertia of the rod. Now you have to add to that the moments of inertia of the masses. Since you are not given radius values, I believe you are meant to assume these are point masses. You should have formulas for the moment of inertia of a point mass.
No need to use the parallel axis theorem.
That value of I is the rotational inertia of that object--that's the answer (if you make the reasonable assumption that the masses can be treated as point masses, not spheres). I don't know what you mean by "it didn't work".
  • · Replies 21 ·
  • · Replies 28 ·
