State space and its subspace : finding a basis
The discussion revolves around finding a basis for a subspace in a 3-dimensional state space, specifically identifying coefficients for a vector that is orthogonal to two given linearly independent vectors. The context involves concepts from linear algebra and quantum mechanics, particularly dealing with complex coefficients and inner products.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore methods to find a vector orthogonal to two given vectors in a complex vector space, questioning the application of the cross product in this context. They discuss the implications of complex conjugates in their calculations and the challenges of proving orthogonality through scalar products.
The discussion is ongoing, with participants sharing their attempts at calculating coefficients and expressing confusion over the results. Some have suggested setting inner products to zero to derive equations, while others are grappling with the complexities of dealing with complex numbers and normalization.
Participants note the challenge of working with complex coefficients and the implications of normalization in this context. There is an acknowledgment of the difficulty in deriving a unique solution due to the nature of the equations involved.
max_jammer
Hello.
I really need help with this one:
I have a 3 dimensional state space H and its subspace H1 which is spanned with
|Psi> = a x1 + b x2 + c x3
and
|Psi'> = d x1 + e x2 + f x3
Those two "rays" are linearly independent and x1, x2, and x3 is an (orthonormal) basis for H.
Now I need to find coefficients g, h and i so that
|psi_othogonal> = g x1 + h x2 + i x3
is not a trivial element of the subspace H1_orthogonal.
not sure
I think that I need to find another element in H which is orthogonal both to |Psi> and |Psi'>
In R3 I would normally use cross product to find the third base vector but how does this transforms to the complex valued coefficients?
I think it may be:
g = (bf~ - ce~)
h = (cd~ - af~)
i = (ae~ - bd~)
where f~ means complex conjugate of f.
but is this right?
Also how would I go about prooving this? What pops in my mind is to build scalar products and see if they give 0...
Thanks a lot
/Nathan
max_jammer said:
I think it may be:
g = (bf~ - ce~)
h = (cd~ - af~)
i = (ae~ - bd~)
but is this right?
Try calculating the scalar products and see what you get. If they're 0, you have your answer.
Thanks for the replay.
I tried to calculate the scalar product but it doesn't work; it all boils down to where I put conjugate. if I put conjugate on
g = (~bf - ~ce)
h = (~cd - ~af)
i = (~ae - ~bd)
then the scalar product of this vector and |psi> is zero BUT
it is not zero with |psi'>...
Or am I missing something?
~z w is generally not equal to z ~w ?
any help is appreciated...
Try going the other way. Set the inner products to 0 and to get two equations involving g, h, and i, which you can solve up to a multiplicative constant.
I did that before and I got expressions for g and h with i as a parameter. (1 equations and 3 unknowns - no surprise there) But I have no idea what i might be. If I were dealing with real numbers I would just set i = 1 and normalize the (g h i) vector, but these are complex numbers and I don't think I can do the same thing.
anyway I got:
g = i (b~ f~ - c~ e~) / (a~ e~ - b~ d~)
and
h = (-d~ g - f~ i) / e~
what am I missing? either my complex algebra is too rusty or there is some fundamental physical relations I didn't think of.
Please help me; this has been bugging me for a week now.
Why not? You don't actually have to set i to 1. You could just normalize the vector, which will allow you to solve for |i|. You still have the freedom to set an arbitrary complex phase, which you can take to be 0.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 67 ·
