The destruction of matter due to spaghettification
The discussion revolves around the concept of spaghettification as matter falls into a black hole, particularly focusing on the fate of matter at subatomic levels and the implications for black hole structure and gravity. Participants explore theoretical explanations for how matter is affected and what happens to it beyond the event horizon.
  • One participant suggests that as matter falls into a black hole, it undergoes spaghettification, leading to the destruction of matter down to subatomic levels, where it may lose properties of matter and gain properties of energy.
  • Another participant challenges this view by stating that energy contributes to gravity, referencing the Stress-energy tensor as a key concept.
  • Some participants propose various explanations for the fate of matter, including the idea that black holes continue to absorb matter at a rate that balances destruction, the possibility of reaching a base particle that cannot be broken down further, and the effects of time dilation on atomic structures.
  • There is a discussion about the nature of quarks and their behavior under extreme conditions, with one participant noting that quarks cannot be separated without creating new quarks, which complicates the understanding of matter's fate in black holes.
  • Another participant mentions that matter can be converted to energy in various processes, countering a claim that energy does not include gravity, while also acknowledging the complexity of these conversions.
Participants express differing views on the nature of matter and energy, the role of gravity, and the specifics of spaghettification. There is no consensus on the ultimate fate of matter in black holes or the implications of energy's contribution to gravity.
Some claims about the behavior of matter at subatomic levels and the mechanisms of energy conversion remain unresolved, with participants acknowledging gaps in current understanding and the need for further exploration of these concepts.
Kamon2011
This is my first time posting on the forums, so please be nice if I mess up :)
My question is this: After matter falls past the event horizon it undergoes spaghettification. Now let's say a human falls into the black hole. His hand enters first and is being accelerated faster than the rest of his body. Therefore he is stretched out and eventually destroyed. Now to go smaller, even his cells would be separated from each other, then the cell itself is stretched and destroyed. Then even the molecules making up the cell would be stretched, breaking the chemical bonds as the atoms are pulled apart, and essentially. Then inevitably the nuclear forces of the atom of pulled apart and the protons and neutrons are separated, then they themselves are destroyed into what they are composed of, and etc. etc.
What I'm getting at is once you get to the subatomic level, the matter starts losing properties of matter and gaining properties of energy, which does not include gravity.
So if all the matter the black hole consumes is eventually destroyed, or converted, to energy, there should be nothing within the black hole to sustain it and continue to bend space. I have proposed a couple of possible explanations:
1. The black hole continues to absorb matter at equal or greater value than it is destroying
2. Some base particle is reached at which point nothing can be broken down further. This still doesn't seem logical cause at this still unobserved value it should be something along the lines of pure energy or strings.
3. The strength of the forces required to break up some stage of matter, like the atom, are so great that time will be dilated to such a corresponding degree that it will never be reached. The atom is essentially frozen in time.
4. And of course the Lupus of the physics world: dark matter some how coexists with matter and is separated and continues to survive inside of the black hole curving space.
Astronomy news on Phys.org
Here's your mistake. Energy does contribute to gravity. Gravity is due to the Stress-energy tensor, of which, energy is a component.
Kamon2011 said:
I have proposed a couple of possible explanations:...
God, another one...
Thank you for telling me, I did not know that :) I'll go do more research on Stress-energy tensor.
God, another one...
Did I do something wrong?
The point at which spaghettification occurs does not have to be at the event horizon. For larger black holes, where the gradient is less severe, it will be closer, and with smaller ones it will be further away I believe.
Maybe. The quarks that make up protons and neutrons cannot be "separated" like other subatomic particles. Usually when we try, such as in a particle collider, the energy used to pull one quark from the other two causes another quark to be created to replace it and create another quark to pair with the one you pulled. Quarks are never found by themselves, but always in groups. What happens in a black hole to matter is currently not known for sure I believe.
Matter always has the properties of matter. There is a widespread misconception about what energy is that I really don't want to get into in this thread lol. Matter can be turned into energy, but I have never seen an example except for annihilation where it turns into photons.
Wrong? Not really. There is just a large amount of people that come onto the forums here on PF and try to explain phenomena that are already explained or they use completely unfounded personal theories with nothing to support it. Most of the time they don't even make any sense and violate current science.
Drakkith said:
... "Matter always has the properties of matter. There is a widespread misconception about what energy is that I really don't want to get into in this thread lol. Matter can be turned into energy, but I have never seen an example except for annihilation where it turns into photons."
Matter is converted to photons in many ways - e.g., radioactive decay, cosmic ray collisions with Earth's atmosphere, chemical/nuclear weapon detonations - etc. Janus correctly notes the contribution of energy to the stress energy tensor. This is why dark energy is such a huge contributor to the effective mass-energy content of the universe.
I've never heard of most of those being matter conversion to energy, but mass. IE the decay of something via alpha particles leaves it's product particles with less mass than they had before the decay, but the matter is all still there. But I can easily agree with the explanation you gave.
  • · Replies 33 ·
9K
  • · Replies 16 ·
  • · Replies 51 ·
  • · Replies 20 ·
