Converting Binary Numbers to Base 10 in Java - Program Help
  • Context: Java
  • Thread starter Thread starter courtrigrad
    Java Program
The discussion focuses on writing a Java program to convert an array of binary numbers (0's and 1's) into base 10. Participants are seeking help with coding issues and logic related to the conversion process.
  • Homework-related
  • One participant shares their initial code and expresses difficulty in obtaining the correct base 10 number.
  • Another participant suggests that the conversion should involve multiplying each binary digit by 2 raised to the power of its index in the array.
  • A question is raised about whether the return value should be the sum of the converted values instead of the final value of numValue.
  • A participant inquires how to adapt the program to handle a boolean array where true represents 1 and false represents 0, and asks about the use of Math.pow.
  • Another participant emphasizes the need to return the sum and suggests modifying the if statement for a boolean array. They also raise a question about the interpretation of the binary representation in the example provided.
There is no consensus on the correct implementation of the program, as participants propose different approaches and raise questions about the logic and representation of binary numbers.
Participants have not resolved the specific implementation details, such as the handling of boolean arrays or the correct interpretation of binary representations.
courtrigrad
Hello all:
I need to write a program that takes an array of 0's and 1's and converts them into base 10 numbers. Here is my code, but I can't get it to return the correct base 10 number.
Code:
 /*  This program returns a value in base 10 from an array of binary numbers.
public class binary
    public int convertBaseTen( int [] a) // method takes an array
    int numValue=1;
    int sum=0;
    for(int i = 0; i< a.length; i++)   // loop through array a
    if (a[i]==1)
        sum+=numValue;
        numValue*=2;
       return numValue;
Any help is appreciated.
Thanks!
Technology news on Phys.org
dont just multiply the number in the array by 2, multiply it by 2^i
i being the integer varibale you are using in the loop to go through the array, because with eah successive element in the array, you are increasing by a power of 2.
for example if you have a number of let's say...5
5 = 101 in binary
101 = (1*2^0) + (0*2^4) + (1*2^2) = 5
if you loop through the array from lowest power of 2 to highest power of 2, and multiply the element by 2^i, and then keep a running total of all that, then you should get the correct answer.
Shouldn't you return sum
Code:
public class binary
    int numValue=1;
    int sum=0;
    if (a[i]==1)
        sum+=numValue;
        numValue*=2;
       return numValue;
How would I write this program which takes in a boolean where true = 1, and false = 0?
Example:
{true, true, false, true} = [1,1,0,1] and then convert this into base 10? Should I use math.pow?
Thanks
any ideas?
1st, return sum, not numValue.
Also, for a boolean array, your if statement would be if(a).
Another thing, is {1,1,0,1} representing 1101 or 1011? (Binary). If it's the second option, changing the return value to sum should be all that needs fixing. If not, you should start at a.length - 1 and go down to (and including) 0 at the array. Then it will calculate the last value and go to the first. In {1,1,0,1} would start at the last 1.
Hope that helped!
  • · Replies 25 ·
