Difference between position time, velocity time and acceleration time graph
The discussion centers on the differences between position-time, velocity-time, and acceleration-time graphs, exploring how each graph is represented and the relationships between them. The scope includes conceptual understanding and technical explanations related to motion and derivatives in physics.
  • Some participants describe the position-time graph as a horizontal line when an object is stationary, while velocity and acceleration are also zero.
  • Others argue that if an object moves at a constant velocity, the position-time graph is linear, the velocity-time graph is a horizontal line, and acceleration is zero.
  • Some participants propose that with constant acceleration, the position-time graph is quadratic, leading to a linear velocity-time graph and a constant acceleration-time graph.
  • A later reply questions the characterization of the position-time graph as exponential under constant acceleration, suggesting it is quadratic instead.
  • There are mentions of integrating velocity and acceleration functions to understand their relationships over time.
Participants express differing views on the nature of the graphs, particularly regarding the shape of the position-time graph under constant acceleration, indicating that multiple competing views remain unresolved.
Some claims depend on specific definitions of motion and may not account for all scenarios, such as varying acceleration or initial conditions. The discussion includes assumptions about uniform acceleration and constant velocity that may not universally apply.
h2chawwaa
What is the difference between position time graph, velocity time graph and acceleration time graph and how would each of them look like when drawn?
exponential, ramp,straight line parallel to time axis
Change of position per unit time is motion and hence, there is velocity there...for as long as velocity is the rate of change of position vs time, we can say that velocity is the derivative of position vs time curve.
Acceleration is the rate of change of velocity per unit time...and so, acceleration is the derivative of the velocity vs time curve.
So, if something is not moving, and it has the same position at all times (horizontal line in y vs t plot), vel=0, acc=0
If something is moving at a constant rate, the plot is an inclined line..its derivative is a constant (slope) which is the speed. The derivative of a constant (speed) is zero (acc=0).
If something is moving at various speeds/acceleration, the position plot will be all over the place, the velocity will be the derivative of such curve, and acceleration that derivative of the speed curve.
There are also relationships when integrating velocity as a function of time and acceleration as a function of time.
If the object is moving at constant acceleration then the plot of position versus time is exponential, a plot of velocity vs time is a ramp ( ie sloped ), and the plot of acceleration vs time is a horizontal straight line.
If the object is moving at a constant velocity then the plots become a ramp, a horizontal line, and a horizontal line with acceleration = 0.
If the object has no velocity nor acceleration then the plot of position is a horizontal staright line and the plots of both velocity and acceleration are horizontal straight lines with velocity=0 and acceleration=0.
256bits said:
If the object is moving at constant acceleration then the plot of position versus time is exponential ...
It would be quadratic, x(t) = x0 + v0 t + 1/2 a t2.
the derivative of an exponential is another expenetial which is clearly not what happens when you differentiate the d-t graph of a uniformally accelerated object, it has to be quadratic, which leads to a linear v-t graph when differentiated and then when differentiated the second time to a horrizontal line
  • · Replies 49 ·
  • · Replies 22 ·
  • · Replies 17 ·
