Differential Equations Verifying Implicit Solution
The discussion revolves around verifying an implicit solution to a first-order differential equation involving the expression \(\frac{dX}{dt}=(X-1)(1-2X)\) and the logarithmic equation \(\ln(\frac{2X-1}{X-1})=t\).
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the differentiation of the logarithmic equation and its implications for verifying the differential equation. There are attempts to break down the differentiation process and clarify steps taken.
Some participants have provided guidance on how to approach the differentiation of the logarithmic expression, while others have shared their own attempts at differentiation. There is a recognition of the need for clarity in the differentiation process, and one participant indicates they have resolved their issue after receiving feedback.
Participants are working under the constraints of verifying a solution without providing complete resolutions, focusing on the differentiation process and the implications of their findings.
Lancelot59
I'm given:
1. [tex]\frac{dX}{dt}=(X-1)(1-2X)[/tex]
2. [tex]ln(\frac{2X-1}{X-1})=t[/tex]
and asked to verify that it is an implicit solution to the first order DE given.
I successfully derived the second equation there to get:
[tex]\frac{dX}{dt}=\frac{-1}{(2X-1)(X-1)}[/tex]
So now what? I tried several things and got nowhere.
Lancelot59 said:
I'm given:
Show us the work you did when you differentiated (not derived) the second equation.
Note that
[tex]ln(\frac{2X-1}{X-1})= ln(2X - 1) - ln(X - 1)[/tex]
so that should make differentiation a little easier.
Note that
I did break it up initially:
[tex]\frac{dx}{dt}=\frac{d}{dt}( ln(2x-1) - ln(x-1))[/tex]
[tex]\frac{dx}{dt}=\frac{1}{2x-1}(2) - \frac{1}{x-1}(1)=\frac{2}{2x-1} - \frac{1}{x-1}[/tex]
Then subtracting the fractions:
[tex]\frac{dx}{dt}= \frac{2(x-1) - (2x-1)}{(2x-1)(x-1)}=\frac{-1}{(2x-1)(x-1)}[/tex]
Starting from your second equation, you have
[tex]t= ln(2x-1) - ln(x-1)[/tex]
[tex]\Rightarrow \frac{dt}{dt}=\frac{d}{dt}( ln(2x-1) - ln(x-1))[/tex]
You have to differentiate the right side implicitly, and then solve algebraically for dx/dt. Can you take it from here?
I solved it! Thanks for the tip.
  • · Replies 105 ·
13K
  • · Replies 23 ·
