The motion of an object acted on by a time-dependent, position-dependent force?
  • Thread starter Thread starter breakfight
    Force Motion
The discussion revolves around solving the motion of a bead on a straight wire subjected to a time-dependent and position-dependent force. The force is defined by the equation F = 9x² + 5xt - 10t², and the bead starts at rest at x = 0. Participants explore methods for determining the bead's position after 30 seconds without friction or gravitational forces.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster inquires about non-iterative methods for solving the problem. Some participants suggest numerical methods, specifically the forward-Euler method, while others raise concerns about its stability over longer intervals and propose alternatives like Runge-Kutta methods.
The discussion is active, with participants sharing differing views on the suitability of the forward-Euler method for the problem at hand. There is acknowledgment of the method's potential limitations, particularly regarding stability and accuracy, and suggestions for alternative approaches are being explored.
Participants are considering the implications of the force's complexity, which includes squared and multiplied terms, and the constraints of the problem, such as the absence of friction and gravitational forces.
breakfight
Is there a non-iterative way to solve for the motion of an object under the influence of a time-dependent, position-dependent force?
Here is an example problem:
A bead on a straight wire is subjected to a net force.
There is no friction between the bead and the wire.
The bead and the wire do not experience any gravitational forces.
The bead has a mass of 1kg.
The net force acts along the wire, and is position and time dependent. It can be represented as
F = 9x2 + 5xt - 10t2
The bead starts at rest at x = 0.
Where is the bead after 30 seconds have elapsed?​
How would one go about solving a problem like this numerically?
Hi,
Sadly there's no way around it :(...(due to the presence of squared and multiplied elements on the right hand side).
This question however, is very reasonably stable using a simple, forward-Euler method. In other words,
[tex] \Large<br /> x'(t) = \frac{(x_{n+1}-x_n)}{\delta t}<br /> x''(t) = \frac{x'_{n+1}-x'_{n}}{\delta t}[/tex]
And substituting accordingly leads to very accurate and tolerable results.
Have you tried using Mathematica, or Matlab? This can also be effectively modeled in C/C++ or any other programming language.
I hope that helps,
Daniel
Sadly, the forward Euler method is often unstable and should almost never be used for solving a DE over s long interval. That's why so many alternative methods (such as Runge-Kutta, etc.) have been developed.
RGV
Oh, I definitely agree... but for short intervals, as is required in the query, as well as just for introductory means, it should work well enough...
Of course, moving on to Runge-Kutta, or some implicit methods should elucidate any issues with accuracy, stability, so forth...
Daniel
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 16 ·
16K
