Rod Constrained at Ends: What is the Lagrangian and Oscillation Frequency?
  • Thread starter Thread starter jncarter
    Rod
The problem involves a thin rod of length 2l and linear mass density constrained to move with its ends on a vertical circle of radius a, where a > l, under the influence of gravity. The task includes writing the Lagrangian for the rod's motion and calculating the frequency of oscillation for small deviations from equilibrium.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the appropriate generalized coordinates needed to describe the rod's position and the formulation of the Lagrangian in terms of these coordinates. There are questions about the potential energy reference point and the correct expression for kinetic energy, particularly regarding the moment of inertia of the rod. Some participants express uncertainty about the treatment of the rod as an extended body and the implications for the Lagrangian.
The discussion is ongoing, with participants providing feedback on each other's attempts to formulate the Lagrangian. Some guidance has been offered regarding the need to consider moments of inertia, while others express concerns about the expectations of the problem based on their current coursework. Multiple interpretations of the problem setup and the necessary calculations are being explored.
Participants note that moments of inertia have not been covered in their current class, raising questions about the appropriateness of the problem's complexity. There is also mention of formatting issues in the equations presented, which may have affected clarity in communication.
jncarter
A thin rod of length 2l and linear mass density of [itex]\lambda[/itex] is constrained to move with its ends on a circle of radius a, where a>l. The circle is in the vertical plane (gravity is present). The contacts between the circle and rod are frictionless.
Part A: Write down the Lagrangian describing the motion of the rod.
Part B: Calculate the frequency of oscillation for small departures from equilibrium.
The Lagrangian: L = [itex]\frac{1}{2}mv^2[/itex] + mgh. Where h is the height and is some function of the angle [itex]\theta.[/itex]
The Euler-Lagrange equation: [itex]\frac{d}{dt}[/itex][itex]\frac{\partial L}{\partial q}[/itex] = [itex]\frac{\partial L}{\partial \dot{q}}[/itex]
The distance between the center of mass and the center of the circle (call it L) must remained fixed, the center of mass moves like a simple pendulum. Its Lagrangian is given by
[itex]L = \lambda l L^2\dot{\theta}^2 - 2\lambda gLcos\theta[/itex]​
and would have a period of [itex]\sqrt{\frac{L}{g}}[/itex].
I can't tell if I have to describe the motion at some point [itex]dl = \sqrt{dx^2 + dy^2}[/itex]from the center of mass (with coordinates [itex]X=Lsin \theta[/itex] [itex]Y =Lcos \theta[/itex]. I think it comes down to a problem with understanding the geometry of the problem. I also can't remember what ends up happening to the Lagrangian of an extended body.
Attached is a picture of the system.Thank you for any help!
How many generalized coordinates do you need to specify the position of the rod unambiguously? What are they? Once you decide on these, then you need to write the Lagrangian in terms of them. Maybe you have done that but the itex code is messed up and I cannot read your equations.
Yah, sorry about that. I didn't know that you can't have formatting commands in with the itex. Better now?
Right now I am using [itex]\theta[/itex] as my generalized coordinate, where [itex]\theta[/itex] is the angle of the center of mass from the center of the circle (the origin). Please look at the attached picture.
Better now, thanks. Your potential energy in the Lagrangian term is almost OK. What is your reference point of the potential energy? If it is the center of the circle, then it is correct that U = - mg cosθ. However, L = T-U, so ...
Now for the kinetic energy term T. This is rotational motion of an extended body about the center of the circle. The kinetic energy then is (1/2)I(θ-dot)2 where I is the moment of inertia of the rod about the center of the circle. So T = ...
This may well be true, but we haven't gone over moments yet in class. I have done so in my undergraduate studies, but I would assume the professor wouldn't give us a problem with it at this point. Also, how would I calculate the moment? Could I just consider it two point masses, each located at |[itex]\frac{l}{2}[/itex]| and add them up?
This doesn't mean that you do not have to use them if needed.
I don't want to second guess your professor, but I can't imagine that he/she would expect you to handle Lagrangians (normally covered at the junior-senior level) without expecting you to handle moments of inertia (normally covered in freshman physics).
No. You would have to find (or look up) the moment of inertia of a rod about its center of mass, then apply the parallel axis theorem as explained here
http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html
I am also working on this problem except i have the added fun of finding [itex]\omega[/itex] for the small departures from equilibrium.
I have found;
L = mlr[itex]^{2}[/itex][itex]\dot{\theta}[/itex][itex]^{2}[/itex] + Ir[itex]^{2}\dot{\theta}[/itex][itex]^{2}[/itex] - 2mlgrcos[itex]\theta[/itex]
does this seem right for a lagrangian?
I have found;
No, the units don't work out at all for every term in your Lagrangian.
I have found;
I think we're in the same class. Caticha?
The problem with your lagrangian is that you have too many terms with units of length (l*r2 in your T term and l*r in the U). Then there is the problem of actually finding the moment. I just can't understand how it comes into things. The two ends of the rod are not rotating about the CM, this isn't a seesaw motion, it's an extended pendulum. Maybe I need to re-draw the picture.
  • · Replies 0 ·
  • · Replies 21 ·
