Solving for Projectile Trajectory: Monkey & Tranquilizer Problem
  • Thread starter Thread starter Trigger
    Mechanics
The problem involves a scenario where a monkey drops from a tree as a tranquilizer is fired at it. Participants are tasked with determining the angle at which the gun should be aimed and the minimum velocity required for the tranquilizer to hit the monkey while it is in free fall, given specific initial conditions.
  • Participants discuss the implications of gravity on the trajectory of the tranquilizer and the monkey's fall. There are hints about considering scenarios without gravity and the relationship between the angle of fire and the trajectory. Some participants express confusion and seek clarification on the minimum velocity needed for the tranquilizer.
Some participants have reached a consensus on the angle of 45 degrees for firing the tranquilizer. However, there remains an ongoing exploration of the minimum velocity required for the tranquilizer to reach the monkey before it falls 10 meters, with various hints and suggestions being exchanged.
The discussion is constrained by the assumption that the size of the gun and monkey can be neglected, and the initial positions are set at 10 meters. Participants are also navigating the complexities of projectile motion under the influence of gravity.
Trigger
Please help with the following problem:
Assume a monkey let's go of a tree when a tranquiliser is fired. At what angle should the gun be pointed so that the tranquiliser hits the monkey while in free fall?
Neglect size of gun and monkey. Let Xm,Ym = monkey's initial position, Vo=magnitude of tranquilizer's initial velocity. What is the minimum velocity, Vo(in m/s) so that the tranquilizer hits the monkey in free fall if Xm=Ym=10m?
What curve describes the tranquilizer's trajectory?Prove it
Hint: What if there were no gravity?
need a better hint!
Answer the question first!
If there were no gravity then the monkey would not experience an accelearation of 9.81 towards the centre of the Earth and the bullet would not fall as it flies through the air also.
Think outside the box.
Solved the first part of the problem, i.e angle=45 degrees. I realize that the tranquiliser should be fired at the monkey and not below it as the tranquiliser falls like the monkey but really need help to find the minimum velocity needed.
PLEASE HELP!
Yep, you got it. So, the shot will hit the monkey no matter what (if it's directed at the monkey). The only problem now is to make the shot reach the monkey before he falls 10 m. Find the time it takes him to fall the 10 m and then see what minimum velocity you need for the tranquilizer to cover a distance of 10 m before the monkey falls.
  • · Replies 18 ·
11K
