Independent components of the curvature tenso
The discussion revolves around the number of functionally independent components of the curvature tensor in the context of Riemannian geometry and general relativity. Participants explore the relationship between the curvature tensor and the metric tensor, particularly focusing on the implications of symmetry and diffeomorphism on the specification of geometries.
  • Some participants present a formula for the number of independent components of the curvature tensor as (n^2)(n^2 - 1)/12, noting discrepancies when comparing this to the components of the metric tensor in specific dimensions.
  • Others argue that for a symmetric metric space, the curvature tensor is completely determined by the metric tensor, suggesting that fewer components are necessary to specify the geometry.
  • A participant mentions that the number of distinct geometries could be represented by 6 functions due to coordinate conditions arising from diffeomorphism.
  • Some contributions highlight that the metric tensor and curvature tensor are distinct, emphasizing the need for additional information, such as the connection, to derive the curvature tensor.
  • There are discussions about the implications of vacuum solutions in general relativity and how they relate to the number of components in the curvature tensor.
  • Participants question whether the divergence equation \(\nabla_{\nu}G^{\mu \nu} = 0\) relates to the ability to specify coordinate conditions and the implications for the number of independent functions needed.
  • One participant suggests that the connection used in general relativity, being both metric compatible and symmetric, could reduce the number of independent components from 20 to 10.
Participants express differing views on the relationship between the curvature tensor and the metric tensor, with no consensus reached on the implications of symmetry and diffeomorphism for the number of independent components. The discussion remains unresolved regarding how to reconcile the formula for curvature components with the geometric constraints imposed by the metric.
Limitations include the dependence on definitions of curvature and metric compatibility, as well as unresolved mathematical steps regarding the implications of coordinate conditions and the nature of the connection in general relativity.
PAllen
Insights Author
2025 Award
A formula I know for the number of functionally independent components of the curvature tensor is: (n^2)(n^2 -1)/12. It gives 1 for n=2, 6 for n=2, 20 for n=4.
However, for a metric space (with symmetric metric), the curvature tensor is completely specified by the metric tensor. For n=4, there are only 10 different components of the metric, and one can argue there are only 6 functions of the manifold needed to specify the geometry, as all metric representations connected by diffeomorphism represent the same geometry.
How does one square this with 20 functionally independent components of the curvature tensor?
http://books.google.com/books/about/A_panoramic_view_of_Riemannian_geometry.html?id=d_SsagQckaQC, p215:
"one cannot recover from the Rijkh, which form a total of d2(d2 − 1)/12 numbers, all of the second derivatives ∂ijgkh, which form a total of (d(d + 1)/2)2 numbers. ... is there enough room between (d(d+1)/2)2 and d2(d2 − 1)/12 to find a nonisometric map between two metrics which still preserves the whole curvature tensor? The subject was initiated quite recently: we know now many examples of nonisometric Riemannian manifolds admitting diffeomorphisms preserving their respective curvature tensors."
Interesting, but sort of the opposite direction I'm coming from. Roughly, they seem to talk about the possibility of different manifolds having the same curvature tensor. I'm thinking there are too many curvature tensors for the number of distinct manifolds (when the latter are limited to symmetric metric, with 'metric compatible' connection). I'm sure there is a resolution, but I couldn't find it either in my books or my own searches of the internet. I'm thinking that the generic (n^2)(n^2-1)/12 formula does not account for hidden dependencies in connection values due to the fact that a metric compatible connection is completely determined by metric components modulo diffeomorphism.
Thanks for anything you can find.
You need only ten because you are thinking of the vacuum solution with the ten components of Ricci tensor curvature vanishing , therefore only has the ten nonzero Weyl components.
There are no known solutions in general relativity with particles stress-energy.
I don't see vacuum as having anything to do with it - symmetry says the metric has only 10 different components. Then coordinate conditions (which amount to modulo diffeomorphism) say the number of distinct geometries would be specified by 6 functions. Whether exact solutions are known is also completely unrelated - this is an implicit function argument.
What conditions are you talking about? [itex]\triangledown _{\nu }G^{\mu \nu } = 0[/itex]?
No, on top of the field equations, you can specify 4 additional, rather arbitrary conditions without loss of generality. These are called coordinate conditions. They arise because any given metric 'expression' is connected to family of geometrically equivalent metrics by coordinate transformation, defined by 4 continuous functions on the manifold. This implies 6 independent functions are sufficient to specify all distinct geometries defined by symmetric metric tensor (in 4-d).
Sorry I might not have read your question correctly, I assumed you were talking about GR.
The metric tensor is not the curvature tensor, you need additional info, the connection, to obtain the curvature tensor.
I am talking about GR. In GR, the choice is made to use a metric compatible connection. This is fancy talk for the connection is completely specified by the metric with the standard Christoffel formula. Thus there cannot be more geometrically distinct connections than metric tensors. Then, the curvature tensor is completely determined by these connections. Thus 6 continuous functions should be enough to generate all geometrically distinct curvature tensors. I'm looking for how to coordinate this fact with the curvature tensor is normally said to have 20 functionally independent components (not 4^4 = 256) in dim=4.
Right if you specify initial conditions for the metric you can still make arbitrary coordinate transformations in the future so you end up with 4 arbitrary functional degrees of freedom. Isn't this made explicit by [itex]\triangledown _{\nu }G^{\mu \nu } = 0[/itex]?
I'm not sure. This is four equations, but my understanding is that this divergence equation is true by construction of G(mu,nu) from the full curvature tensor. Maybe it is equivalent to the ability specify 4 coordinate conditions. I'll have to think on that. Post any further thoughts of yours on this, as well.
PAllen, if you carefully thought about it I think you'd remember the connection used in GR is not only metric compatible but also symmetric. That 's all you need to go from 20 to 10 components IMO.
Hmmm, Berger says that 20 curvature conditions are too few to determine the metric, whereas you say those are too many (ie. the 20 cannot all be independent)?
Naively, I'd think it'd be too few, maybe like there are more component Maxwell equations than E and B field components, and yet the fields are underspecified, since one has to add in boundary conditions.
Berger does comment that if we go to Riemann normal coordinates, then at the origin the curvature components do determine all second partials of the metric. However, this is because going to normal coordinates brings in additional information beyond the curvature (I'm not sure what exactly this additional information is).
Right, I thought about that later, but didn't mention it. So then there is only the discrepance from 10 to 6.
[Edit: wait, I'm not sure it decreases it by that much. You may be right. Can you post an argument or reference that symmetric metric reduces independent curvature components that much?]
The whole point of my question is how to square arguments like this with the fact that (in GR at least), the metric completely determines the curvature tensor and has only 6 functional degrees of freedom.
Hmm, let's see: the metric defines the curvature, but the curvature does not define the metric.
I thought you were asking about the second part of that statement, but you are asking about the first?
I don't have a reference, but you certainly save all the torsion tensor components of the curvature, it is kind of obvious.
From ten to six usually the argument is used that four of the ten would be fixed by the test particle coordinates, but this would only work for vacuum solutions, as I explained above no other kind of solutions are known for test particle stress-energy so no one cares much about that discrepancy (two body problem is still not solved in GR).
I'ts obvious to me you save some. It's not obvious to me that you get from 20 to 10 just by assuming symmetric connection.
I don't see the 10 to 6 argument as having anything to do with vaccuum/non-vaccuum. It is derived assuming nothing other than that the metric is symmetric, and you have diffeomorphism invariance.
I am asking you one can really say there are 20 functionally independent components of curvature when it is completely derived from tensor with 6 functional degrees of freedom. So, in least in the context of assuming a symmetric metric tensor (which leads to the 6 figure), this suggests to me there must be a great many implicit dependencies between the curvature components, beyond the 20 figure derived from Bianchi identities and interchange symmetries.
I provided you with the argument usually given.
Do you have any reference with the 10 to 6 components derivation? If so, can you share it? But then why would you ask for it if you already have that derivation.
Well, it turns out not even that you save some should be obvious because the Riemann tensor formula that gives the 20 components is constructed accounting already for the fact that the Levi civita connection is used.
Sorry about the misleading lead.
I'm really curious about this too, hopefully somebody will enlighten us.
If [itex]f\left(x,y\right) = xy[/itex], are [itex]\partial_x f[/itex] and [itex]\partial_y f[/itex] independent?
Surely not, and? You mean I was right, then?
I am not asking about the 10 to 6, I understand that fully (I think). I am asking about how to understand this fact along with the derivations that there are 20 independent components to the curvature tensor (which I also understand, read in isolation). Maybe something as simple as " Oh, this is well known to the experts, it is covered in such and such".
As for the 10 to 6, the books I have don't formally derive, the simply justify with the following type of argument (in several variants):
Supposing you have the set of all possible symmetric metric tensor representations. Pick one; then all other representations connected to this one by diffeomorphism are describing the same geometry. Diffeomorpthisms are described by a 4 functions in 4-dim. Thus 4 identities can be added without loss of generality (effectively picking one representation from those equivalent by diffeomorphism). Four identities applied to 10 functions leaves you 6 functional degrees of freedom.
Well, x and y (the partials) are independent, but you cannot arbitrarily choose functions for the partials and have them satisfy the condition that they represent partials. You have only one functional degree of freedom due the requirement that they be partials of one function.
So is this mostly a matter of terminology? Different senses of the word independent? What is a clear terminology to use here?
I mean, by one set of arguments, we have there there 20 independent components to the curvature tensor. By another set of arguments, we conclude that there are only 6 functional degrees of freedom in the choice distinguishable metric spaces with symmetric metric and metric based connection. So am I right that most possible arbitrary functional choices for the curvature tensor [even after satisfying Bianchi identities and interchange symmetries] would fail to be the curvature tensor for any symmetric metric space? In the same way the two arbitrary functions are unlikely to be partial derivatives of any possible single function?
Here, I think "independent" means "linearly independent" in some appropriate space.
Choose some coordinate basis.
Then you can write the components [itex]\Gamma_{\alpha\,\beta\,\gamma}[/itex] in terms of the metric coefficients and their derivatives.
Proceeding on, you can write [itex]\Gamma^{alpha){}_{\beta\,\gamma}[/itex] in terms of the previous plus the metric, then you can write [itex]R^{\alpha}{}_{\beta\,\gamma\,\delta)[/itex] in terms of [itex]\Gamma_{\alpha\,\beta\,\gamma}[/itex] and it's derivatives [itex]\partial_{\mu} \Gamma_{\alpha\,\beta\,\gamma}[/itex]
So the first fundamental question you need to answer is George's - simplifying it to one variable, are f(x) and [itex]\delta_{x} f(x))[/itex] independent?
I'm not sure I know what context you're thinking about the question in but in the context of the evolution of f(x) evolving as an initial value problem satisfying a second-order differential equation, they're generally independent.
This is IMO a reasonable context, because if you think of some globally hyperbolic space-time evolving in terms of an initial value formulation, the evolving metric satisfies some second order hyperbolic quasi-linear differential equation
But that doesn't mean it's the context you were thinking of the problem in. But if you consider the remarks and answer George's question, you should be able to answer your own.
Ok so the symmetric connection and symmetric metric reduces the 20 components to 6, not to ten, then?
  • · Replies 24 ·
